Old 08-30-2017, 08:19 AM   #1
Fuse panel
I have a 2008 sandstorm. With two 6. Volt new batteries. When I turn on generator the 30 amp fuse got so hot it melted plastic around it?? Overheating fuse area???? What's causing this?
Buckaroojohn is offline   Reply With Quote
Old 08-30-2017, 02:25 PM   #2
If the fuse didn't blow, then it's most likely a loose connection that's arcing.
We are talking about fuses and not breakers aren't we? Though the same applies to either situation.
Gotta go campin!
Old 08-30-2017, 02:55 PM   #3
Yes sir. Thanks. Loose fuses did it
fuse
