Old 04-02-2016, 10:55 AM   #11
Spend the extra money for an inverter generator.
You will be glad you did.
The money saved will be a distant memory when you have to deal with unhappy neighbors.
2016 Jayco Eagle 330RSTS = "Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = "Hagrid"
360 degree Virtual Tour
Fairenatic is offline   Reply With Quote
Old 04-02-2016, 01:15 PM   #12
3 db is not twice the sound level, it is around 1.6 which is significant. 3 db when related to power is double. 68 db would be quite a bit louder than 58.
Brewhedd is offline   Reply With Quote
generator
