with an RV transfer switch, the Generator's output will take over priority when you are also on Shore Power, though it has a 'wait time' for this to happen, since the generator needs to get up to 'spool' for 120v output before the ATS recognizes the power...
but, no, you don't 'need' to unplug, EVEN if you still have Shore Power, such as if you want to exercise your generator monthly while parked for extended stays.
The ATS is what takes action when you have TWO 120v power sources. Normally most RVrs will either 'unplug' before they run the generator, or will have turned OFF their generator before plugging in, but even if not, the ATS can handle it with ease - that's it's job.
Now, the reason that the ATS gives preference to Generator power, when you have BOTH the Generator running AND live Shore Power, is because, of course, it CAN'T use both at the same time, but must 'choose' which is the 'default' power source when both are present - the Generator gets the preference.
Some folks find it uncomfortable to remain plugged in when running the Generator, but ultimately there's no issue if you allow this, as many of us do.
The Turners...
