Old 11-17-2014, 07:35 PM   #21
TURBS's Avatar
Try turning fan to on with ac off then turn a/c on.
I know it's under warranty but maybe we can get you going.
I have a mod that starts the a/c compressor first then 15 seconds later starts the fan.
Works well for smaller gennies.
TURBS.
Old 11-17-2014, 07:41 PM   #22
What typically happens is that the fan turns on then after about 15 seconds the compressor kicks on. But I'll try it when I'm back from our walk.
Name:	ImageUploadedByForest River Forums1416271168.130393.jpg
Name:	ImageUploadedByForest River Forums1416271274.046962.jpg
ShooterGuy is offline   Reply With Quote
Old 11-17-2014, 08:11 PM   #23
TURBS.
Well... This did not work. I'll just have to warranty service it I suppose. Good thing it's not really hot out.
Old 11-17-2014, 08:28 PM   #24
You may want to get the mod which installs a capacitor for cold starts. Should help alot, your AC may use 30amps on start, but then only 10amps after that. That would make it only use 10amps all the time.
proggod is offline   Reply With Quote
Old 11-17-2014, 08:34 PM   #25
TURBS's Avatar
a doemetic a/c requires approximately 18-19 amps to start and 12-14 running.
The capacitor is normally referred to as a "hard" start capacitor not cold start.
That gennie should be more then capable of running the a/c and other appliances.
TURBS.
Old 11-17-2014, 08:34 PM   #26
B and B's Avatar
What fuel does the generator use? Found it Gas according to the picture.
B and B
Old 11-17-2014, 08:39 PM   #27
TURBS's Avatar
The generator has an issue either the case.
Without knowing voltage and amps it's a crap shoot.
TURBS.
Old 11-17-2014, 08:44 PM   #28
B and B's Avatar
The Model Number on the Picture is 120 V 33.3 amps but the Breaker is 30 amps so that is max draw if the breaker is 100% capable, none are I would say 90% max load on the breaker.
If the 15 K Acon is started with the hot water heater the breaker would blow.
B and B
Old 11-17-2014, 08:52 PM   #29
TURBS.
What he said..
Old 11-17-2014, 08:55 PM   #30
TURBS's Avatar
Brian my gennie is 30 amps and has a 30 amp breaker.
I can run a/c, HW heater and converter without popping breaker.
TURBS.
Old 11-17-2014, 09:04 PM   #31
Also you don't HAVE to get warranty work where you bought it, call around and find someone else that will do warranty repairs that doesn't take so long..
Old 11-17-2014, 09:39 PM   #32
B and B's Avatar
TURBS.
Need numbers, as per your post...
OP....One thing that would tell the story is shore power. Does that work?
B and B
Old 11-17-2014, 11:15 PM   #33
SKnight's Avatar
Check the oil level. If it's marginal then when it's running at a low engine speed it's fine. But load it and as the engine revs up the oil gets slung around the crankcase effectively lowering the level in the sump which could be tripping the oil level sensor and shutting the engine off.
If you're overloading it then it should lug down and kick the breaker. But it just shutting down when loaded tells me a safety alert is kicking in, oil level is the easiest to check.
And it doesn't have to be "Low" to trip the sensor. My Honda can be halfway down the crosshatch on the stick and trip the level alert.
Old 11-17-2014, 11:16 PM   #34
I did check the oil level. It's good and looks brand new.
Old 11-17-2014, 11:36 PM   #35
B and B's Avatar
Wish I was on the Beach its 19 F here now and with windchill -2 F. Beach=Nice.
I hope you find out the issue. Ones question, have you ever run it on Shore Power?
B and B
Old 11-17-2014, 11:39 PM   #36
Yes. We have. Our first time taking it out we ran the ac on shore power without issue.
Old 11-18-2014, 09:17 AM   #37
Have a generator similar to yours at work on a hazmat trailer. It has a switch that you have to use when placing generator under a load. It is located right in front with the cover off. Maybe yours has one also.
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
racerx is offline   Reply With Quote
Old 11-18-2014, 09:29 AM   #38
TURBS's Avatar
And what's the switch do?
TURBS.
Old 11-18-2014, 09:37 AM   #39
It is a 30 amp breaker switch that is off to start and run generator to warm up or periodic runs.Than switch to place under load.
Old 11-18-2014, 09:38 AM   #40
TURBS's Avatar
Interesting!
TURBS.
generator
