Old 11-17-2014, 04:44 PM   #1
Exclamation Generator + A/C = Problems
So....
My wife and I are out camping at the beach, without hook ups and decided to turn on our generator and charge our batteries some. Well, we decided to turn on our A/C too. The A/C fan turns on and as soon as the cooling part kicks on the generator stops. It is an Onan, at it is giving me error code 13, "UNDERVOLTAGE FAULT: Generator unable to maintain rated voltage" I have nothing else plugged in.
So what could be causing this?
My rig is a 2014, forrest river Stealth 2116.
2nd time camping it in, first time boondocking.
Thanks for your help!
Cliff
ShooterGuy is offline   Reply With Quote
Old 11-17-2014, 04:57 PM   #2
fonzie's Avatar
Make sure your water heater and fridge is on propane only and try again....
Fonzie
Old 11-17-2014, 05:02 PM   #3
How many amps is generator, sounds like it can't produce enough power. When your A/C first kicks on there is a huge draw. You can buy a cold start kit, which is basically a big capacitor that would help with that for the AC
proggod is offline   Reply With Quote
Old 11-17-2014, 05:02 PM   #4
The water heater is gas only, and is off anyway, but the fridge was set on auto. I turned it to Gas. I then turned on the AC and same thing. I will give it a few minutes with the fridge on gas then try it again.
Old 11-17-2014, 05:07 PM   #5
4000 watts, 60 Hertz, 120 volts, 33.3 amps
Old 11-17-2014, 05:08 PM   #6
I've ran the AC before on just the generator, not sure what has changed now.
Old 11-17-2014, 05:17 PM   #7
Generators can get weaker with time, and appliances like the A/C could draw more power. Whats the model number of the generator?
Old 11-17-2014, 05:21 PM   #8
Name:	ImageUploadedByForest River Forums1416266456.324071.jpg
This whole rig is brand new. Less than 5 hours on the generator.
Old 11-17-2014, 05:26 PM   #9
ironj's Avatar
if your batts are real dead, and/or you have the converter pumping out 12v otherwise, that will eat up some genny amps....try switching off the converter then letting compressor kick on , THEN turn converter back on?
2015 F350 Platinum Fx4 6.7 Diesel Dually. B&W turnover, B&W Companion, air bags and wireless controller.
2015 Heartland Road Warrior 420 Rt
2012 f250 Fx4 6.7 Diesel crew cab tinted n tuned
2012 lacrosse 318bhs touring- sold
ironj is offline   Reply With Quote
Old 11-17-2014, 05:39 PM   #10
I'll be perfectly honest, I have no idea how to turn off the converter. I know all that stuff is located under the bed, and when I look at it, all I see is a bunch of wires. #notelectricallyinclined.
generator
