Old 06-24-2018, 02:20 PM   #1
Generator/AC Unit power
Hello. I have a 3250 watt generator and a 13500 btu AC unit on my Salem. For one weekend Iím going to need to find a way to supply power to the AC unit without shore power. My generator only has two normal wall outlets though, so my question is there an adapter that will allow me to connect both of those outlets to my 30 amp connection to give me the power to do this?
HappilyLost is offline   Reply With Quote
Old 06-25-2018, 05:51 AM   #2
Mainframe's Avatar
Yes you can get an adapter, they usually sell them at RV dealers and I have even spotted them at wl mart, some campground stores carry them also, you Gen should run your A/C with no problem
2016 Shamrock 23WS
Mainframe is offline   Reply With Quote
Old 06-25-2018, 06:44 AM   #3
cavie's Avatar
https://www.amazon.com/Camco-PowerGr...AXBVE3VD9Q8MKM
https://www.amazon.com/TruePower-Ele...AXBVE3VD9Q8MKM
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 06-25-2018, 07:48 AM   #4
If I hook into just one outlet though will that be enough power? Each outlet is 20 amp
Old 06-25-2018, 08:02 AM   #5
1 outlet will be enough to run the a/c unit.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 06-25-2018, 08:03 AM   #6
cavie's Avatar
You can only use one outlet. Your AC only needs 15 amps. You will be fine. You can use a light or two also. Everything else will need to be on gas,
PS. Technically 12.5 amps. Thought I'd better fix that before somebody yelled at me.
Old 06-25-2018, 08:07 AM   #7
Also run your hot water heater on propane. We often go to a military campground that is full but we camp in the overflow sites with just 20amps. We have two a/c but one is small and we run the small one and cut the other one off
Old 06-25-2018, 09:18 AM   #8
Flybob's Avatar
You should also turn off the breaker to your converter. The AC will run fine on 20A, the big issue is when it restarts hot the peak draw may trip the breaker on the generator if there are other loads.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
generator, power
