Old 04-11-2016, 06:43 PM   #11
B and B's Avatar
I love the Honda's but the costs to get into them in Canada is close to 3 grand with extended run tank. I opted for a Powerhouse 4 kW Invertor with Fuel Injection. One tank running full load with AC will last 10 to 14 hours. Cost was $1200 CDN at the trailer show. Runs great, remote electric start.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-11-2016, 06:47 PM   #12
rsdata's Avatar
sfsgm
the Generac iX2000 probably will NOT run an AC unit, but if that does not bother you I have seen them in action and they are pretty quiet and certainly capable of powering anything up to the AC unit... and Costco price of $500 makes it affordable
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
rsdata is online now   Reply With Quote
Old 04-11-2016, 07:23 PM   #13
Blog: RVroadtripper.com
hbillsmith's Avatar
Champion just released the 3100 Watt Inverter Dual Fuel model. You can run either Gas or Propane. Its electric start, weighs 93# and the noise level is 59dB. It just went on sale at Cosco for $150 off the already cheap Cosco price so its $849 (ships free). I have had the 3100 gas only version for 2 years (paid $750). If I could sell mine, I would go for dual fuel in a heart beat.
Champion DUAL-FUEL 2800wt Running / 3100wt Peak Digital Inverter Generator, Electric Start, RV Ready, Parallel Capable, CARB & EPA Certified, Low Decibels
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 04-11-2016, 08:27 PM   #14
Boliy inverter from BLT is what I use and prefer. Has larger continuous power capacity then others in its class.
Skyliner is online now   Reply With Quote
Old 04-11-2016, 10:16 PM   #15
Hbillsmith, will that run a TH set up for a 4kw onan?
Tigertrump is offline   Reply With Quote
Old 04-11-2016, 10:28 PM   #16
running a boliy 3600 nice inverter quiet running and fair easy on gas
buck66 is offline   Reply With Quote
Old 04-12-2016, 12:50 AM   #17
Running Champion's, quiet and reliable.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 04-12-2016, 01:18 AM   #18
hbillsmith's Avatar
Champion Inverters are external portables. Onans are usually installed internal in a cavity prepped and vented. You would not run a portable external in a cavity designed and setup for an Onan.
As far as running it external and addressing what can run, its 3100 watts on gas and 2800 watts when running propane. It will run one A/C at a time. LED televisions and lights no problem. Put your hotwater heater, frig and furnace on gas.
Old 04-12-2016, 06:37 AM   #19
Hbillsmith, good info. Thank you.
Old 04-12-2016, 06:44 AM   #20
How does an "inverter" generator differ from a "normal" generator? I eventually plan on getting one of the generators from Harbor Freight.
2016 Heritage Glen 272RLS
2017 Dodge Ram 2500 Big Horn, 6.7 CTD, 4x4
KRSmitty is offline   Reply With Quote
generator
