Old 04-12-2016, 05:20 PM   #31
The Briggs and Stratton P3000 looks nice and can be paralleled. Thoughts?
vort is offline   Reply With Quote
Old 04-12-2016, 06:33 PM   #32
I think the $500 COSTCO genset you mentioned is a contractor-type v. a quieter inverter. If so, I think you'll find it very noisy unless you're boon-docking by yourself and don't care. Whatever you do, make sure the one you buy will run everything you need it to. I was able to run an older 12k AC on a prior FW with Honda EU3000, but it will not run even the smaller of the two ACs in our current FW.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 04-12-2016, 06:45 PM   #33
Dazed & Confused
M&K Hoffman's Avatar
I also give a to the Champion 75531i. Quiet and dependable and will run one AC unit.
~Mike & Kim~
2014 Rockwood Windjammer 3008W Diamond Package
2012 Toyota Tundra Doublecab 5.7 4WD
M&K Hoffman is offline   Reply With Quote
Old 04-12-2016, 07:22 PM   #34
Rclogg, would you suggest this to run a tt TH rather than a 4K onan unit?
Tigertrump is offline   Reply With Quote
Old 04-12-2016, 07:44 PM   #35
B and B's Avatar
Originally Posted by rclogg View Post
I bought a Lifan 4000Watt Inverter. EFI, remote and electric start, 12hrs run time @ 50% load and just as quiet as a Honda my Honda 2000ie (We carry both). $1200 shipped to Home Depot, 30 day return to the store. Used a Home Depot CC and got 12 months - 0%.
Energy Storm 4000iER EFI Inverter Generator Lifan Power USA
This is same as a Powerhouse except the Powerhouse has wheels I took off anyways to fit under my Tonneau..
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-12-2016, 08:06 PM   #36
The_Rhino's Avatar
I just bought (2) WEN 56200i 2000-Watt 79.7cc Inverter Generators for $379.99 each on the Woot! website.
IMO they are Yamaha clones right down to the engine. They are probably made on the same Chinese assembly line with only slight cosmetic differences for branding purposes. I can't risk $2000 worth of generators getting stolen so I'm sticking to these.
2011 RAM 2500 ST Crew Cab 5.7 Hemi ($14K in '13)
2011 Primetime 3150BHD Touring Edition ($20K in '14)
Days camped in 2017-31
2016-36; 2015-37; 2014-31
The_Rhino is offline   Reply With Quote
Old 04-13-2016, 09:35 AM   #37
rclogg's Avatar
I couldn't afford the Onan, plus this is back up for the house.
'14 Cummins Dually Aisin 4.10
'07 FR Cardinal LE 30RK
'03 Cummins Dually 45RF
'01 Exiss 300MT Weekender
A wife and two dogs, isn't that enough?
rclogg is offline   Reply With Quote
Old 04-13-2016, 09:59 AM   #38
Blog: RVroadtripper.com
hbillsmith's Avatar
When you say "backup for the house" you entered new territory. You should tally up the amp draws of what you will be running in the house. If you go too small you may limit yourself. Lifan sells the 7000 watt version of the previously mention 4000 inverter. Ive seen it on the Internet for $1,650 (Lowes I believe). Its quiet, more power, 47amp. Downside is weight, its on wheels but weighs about 200# as I recall. The 4000 and 7000 Lifans are fuel efficient, carboraterless fuel injected like the large Honda 7000is.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 04-14-2016, 06:22 AM   #39
I saw that sale and also wanted to get two, but waited too long, ..... did some research during the day and found a site with noise ratings for small gen. and that model was the lowest listed 51dba, ...... Woot has sold that one several times in the past, but usually $10/$20 more, .. that was a good deal,....... hope they serve you well..................
fella10 is offline   Reply With Quote
Old 04-15-2016, 12:40 AM   #40
RangeMaggotBob's Avatar
I've read for a while now about all these generators, and every once in a while somebody says, "Not as quiet as a Honda, but close". Personally, and this is just me, I'm going with the two Honda 2000s. They seem to always run, very seldom any problems, and there's a zillion Honda dealers in the U.S., and they are so darned quiet! Normally, I'm pretty cheap, and my wife constantly lets me know this, but this time I'm going to bite the bullet. But they sure won't come down a single penny on their prices! Still right around $999.99, give or take a few pennies.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2000i generators
RangeMaggotBob is offline   Reply With Quote
generator
