Old 04-15-2016, 12:59 AM   #41
flymhi's Avatar
I've had the Honda EU2000 and more recently the EU3000is. I sold the 3000 due to the weight of moving it around and bought two Generac IQ2000s. I have to say they are as quiet as the Hondas and seem to perform well with the auto-throttle on loads. I puchased the two Generacs and the parallel unit for $1500 so I'm very happy with the power for the money. I plan mostly running the single unless I need the A/C. They sure are easy to move @ 40lbs compared to 80lb.
2015 Denali Duramax 2500
2017 Coachmen 229TBS
2010 Shamrock 21SS - sold!
flymhi is offline   Reply With Quote
Old 04-15-2016, 01:50 AM   #42
SYE
SYE's Avatar
Thanks for the input. On our Columbus group, everyone wants the honda's I was looking into buying the setup that you did. Thanks
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 12 Nights Camped 2018 57 nights reserved
SYE is offline   Reply With Quote
Old 04-15-2016, 01:54 AM   #43
SYE
SYE's Avatar
Here are a couple short videos that a friend shared with me
Scott & Vicki
Old 04-15-2016, 09:15 AM   #44
Blog: RVroadtripper.com
hbillsmith's Avatar
Great solution. Its nice to be able to just run one in the fall and spring when you dont need A/C. My buds that have this setup all added a marine gas tank and dual fuel feed. They said it was much easier than tying to keep adding gas to two small tanks. Also dont foget to buy the Honda parallel kit. Got the fill kit on eBay I believe. One small conideration is that 2 2000's together is noisier than one 3000is.
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
Old 04-15-2016, 09:46 AM   #45
Love my Yamaha 2000isV2's. I run two of them in parallel. I get lots of compliments from my fellow campers. They really appreciated the very low sound level (45dB). They only weigh 46lbs so it makes it easy to move around and store. They fit easily into the pass through and are extremely efficient. I ran them for four nights and used 10 gallons of fuel.
Yes, they are more expensive than most but the fuel shut off valve in itself is worth the price of admission. Ethanol is a big problem so unless you want to be cleaning\rebuilding your carbs every other season, keep it in mind.
Its also nice to be a good neighbor. You do not want to be the one in camp irritating the rest of those around you.
2016 Jayco Eagle 330RSTS = "Madame Maxime"
Maxxis M8008 E rated Tires and 16" Wheel Upgrade
Dual A/C, 14K Equalizer WD hitch with SC
King Bed with Java Interior, (2X) Yamaha EF2000isV2
2012 Ram 4500, 6.7L Cummins TD, MegaCab = "Hagrid"
360 degree Virtual Tour
Fairenatic is offline   Reply With Quote
Old 04-15-2016, 11:10 AM   #46
You must have an exceptional model, the Yamaha 2000isV2 is rated at 51.5 db (no load) - 61 db (full load), which is pretty impressive.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 04-15-2016, 02:46 PM   #47
I recently bought the generac iq2000 at Cabelas. I got a hundred dollar gift card as well. I've used it twice. Very quiet and seems well built. Very happy with it.
VibeRaider is offline   Reply With Quote
Old 04-15-2016, 07:21 PM   #48
hbillsmith's Avatar
Originally Posted by hbillsmith View Post
Champion just released the 3100 Watt Inverter Dual Fuel model. You can run either Gas or Propane. Its electric start, weighs 93# and the noise level is 59dB. It just went on sale at Cosco for $150 off the already cheap Cosco price so its $849 (ships free). I have had the 3100 gas only version for 2 years (paid $750). If I could sell mine, I would go for dual fuel in a heart beat.
Champion DUAL-FUEL 2800wt Running / 3100wt Peak Digital Inverter Generator, Electric Start, RV Ready, Parallel Capable, CARB & EPA Certified, Low Decibels
If you live in Texas and are interested in this Champion Inverter Dual Fuel on sale at Costco for $850 you can buy it this Texas Tax Free Weekend and save another $70. Texas considers generators as storm standby and included them in this year's exemption. Great buy they will sell out.
Old 04-15-2016, 10:55 PM   #49
I've done a lot of reading on the inverter generators the last few days. This Champion looks like a great buy. 1 question I have for you experienced RVers. The TT I'm looking at buying has an upgraded 50amp service but pre wired for an Onan 4K. Do you think it will work with the Champion 3100? Thanks for input.
Tigertrump is offline   Reply With Quote
Old 04-15-2016, 11:38 PM   #50
hbillsmith's Avatar
Your TT external shore power cable will require a 50amp to 30amp adapter and this will then plug into the Champion but keep in mind you will only have 30amps of power to run things. Most of us that carry 30amp inverters do so because they are lighter weight and cost less. As a result we know to run only one A/C at a time or perhaps dont run a hair dryer with A/C on or the reset pops. Not a huge trade off, just something to manage. If your TT was upgraded to two A/C that is the most likely reason it is 50amp.
If you choose an external Generator or Inverter, you will not be using the Onan prewire. Onans are great units and most convenient, its usually simply a price point that keeps one from doing it. Lastly, I believe an Onan install adds the need to install a gastank in the trailer. Since Toyhaulers already have gas on board, you will find more Onsn prebuilds with that type.
generator
