Old 04-16-2016, 06:37 AM   #51
HBillSmith, thanks for the input. I'm not experienced in the TT world at all. It's why I'm on here reading and learning. I like the Onan myself but figured if I could save a few thousand may be worth it. The TT TH im considering has just 1 AC is why I figured it could handle it. Im saving a few more pennies before I buy and will then make a determination. Enjoy and appreciate all the input from you and others.
Tigertrump is offline   Reply With Quote
Old 04-16-2016, 07:32 AM   #52
I have a Onan 5500 quiet gen set in the fiver and works great. I do have a Generac 7k for my house and that thing is a beast and starts up quick even after sitting for a few months when I forget to test run her monthly but it is not quiet by any means. Lol. Of course, it is for house use and is outside the garage when needed. It is very reliable though. Had her 4 years and zero issues. At times, the fuel will sit a while but I do use Lucas ethanol stabilizer and try to run her every so often to keep the carb clean.
Doc
____________________________________
2014 V-Cross Platinum 365VTSB (Bought Labor Day 2014)
TV: 2016 GMC 3500 Denali - Motor Ops Tuned
Days Camped 2016: 28
Days Camped 2017: 25 so far
DocGTO is offline   Reply With Quote
Old 04-16-2016, 08:18 AM   #53
Gold Miner At Heart
Papa-t's Avatar
Two Honda eu2000 With parallel kit. Easier to load one at a time. When camping I switch off running one at a time to charge the battery but can use both if running air. Very quiet.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
Papa-t is offline   Reply With Quote
Old 04-16-2016, 09:29 AM   #54
BendOrLarry's Avatar
You will like the Champion 3100 I had a Honda and like my Champion just as much.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 04-16-2016, 09:37 AM   #55
I concur regarding the Champions. I came across them by accident, but their design is no accident! 100% designed for the RV Market. Amazing how inexpensive and perfect. They have a wide selection. For those that only need a single 30amp line consider the model 100222 that I purchased at your local LOWES. It is already wired for a 30 amp RV connection as if you are plugging in at a pole! No adapters needed. Here is the link
3400W/4000W Generator, 224cc - Champion Power Equipment
'17 270S
270S is offline   Reply With Quote
Old 04-16-2016, 09:58 AM   #56
The 100222 is not an inverter and quite loud.
Humteddy2
2014 Silverado Z71 LTZ 1500
2017 Surveyor 285IKDS
Humteddy
2017 Surveyor 285 IKDS
2016 GMC Sierra Denali HD 2500 Duramax
Humteddy2 is offline   Reply With Quote
Old 04-16-2016, 10:38 AM   #57
No Kidding - a generator. But it does the job and you don't need 2 in parallel to get 30 amps or run your AC. It may produce noise, but all of them do, it's a question of how much.
The point I was making without getting too technical, it is a single phase generator! NOT the standard multi-phase that only lets you use half of the output it creates unless you are using 240Vac. That would mean you would need an 8K multiphase to do the job of the 4K single phase. My point is that the 100222 does the job of a LOUDER, HEAVIER, more EXPENSIVE 8K.
I spoke to a person the other day that was passing through with his TT and his Honda 2000 gets too hot (has a metal box around it to not get burnt!) and it will not run his air conditioning - and he only has the 13500 BTU ac.
Regarding Sound, it is 68 dBa at 23 ft. I will try to be more than 25 feet away, ...
If you want an invertor generator, Don't purchase a 100222, but if you want the real thing, consider a 100222 that's all. BTW, Champion makes an IG version that was in the link I provided.
'17 270S
Old 04-16-2016, 10:39 AM   #58
my yamaha ef3000iseb has been great. has 1000's of hours on it have owned it for 8 years or so. Runs a good 20 hours on full tank on low setting only about 2 1/2 gals. it is heavy though will run ac fine. If i was to buy again it would be two 2000 yamahas ran together much easier to lift
1999 dodge 2500 Diesel 4x4
2016 Wildcat Maxx
282rkx
aupainter is offline   Reply With Quote
Old 04-16-2016, 02:33 PM   #59
bikendan's Avatar
Own Champion 3500w (100222)and Honda 2000i.
Champion is for home backup power and the Honda is for camping.
NO WAY would I subject my fellow campers nor myself to the noise level of the Champion.
Moving it farther away will probably put it closer to another camper.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-16-2016, 03:02 PM   #60
Butch Wilson's Avatar
My goal was to get the quietest generator for camping as possible. That is the Honda 3000 . The added plus is it will run my air conditioning if needed.
Butch Wilson is offline   Reply With Quote
generator
