12-20-2016, 05:05 PM
#41
they have a parallel kit.. the one for the champions just fits between the two stacked units and provides your 30Amp plug..
12-20-2016, 06:05 PM
#42
Originally Posted by FreeDivr
Another question while generators are on topic, does the TT plug directly into the generator or does it need additional plug or something?
The Champion 2000 parallel kit (about $60) is RV ready, just plug your trailer cord into it.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
12-20-2016, 07:28 PM
#43
You can exceed your amp draw with shore power, but with a generator, what you get is all you have. As with buying an air compressor, be sure you have enough to cover your needs.
12-20-2016, 10:26 PM
#44
IMHO Honda or Yamaha are the best two choices. Both are reputable , have good inverter models and most importantly are QUIET. Been running a 3000W Yamaha for the last three years. We do a lot of dry camping and love it. I put an hour meter on it last year so I can service it at the proper interval. Downside is, that a large good quality generator is heavy. Mine I believe is 147lbs when full of fuel.i leave it on the back of the truck and haven't had to unload it in the past two years. If I do, I get a hand with it.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
12-20-2016, 11:13 PM
#45
Glad that is your opinion only and not based on any factual information. They are all good actually.
A word of caution on any genny is maintenance. They need regular care and above all fresh fuel and/or fuel with stabilizer added for overwintering.
12-20-2016, 11:24 PM
#46
I went with the Champions running in parallel. I added an external fuel tank for extended run time. They work great for my needs.
2018 Refection 311BHS
2011 Wildcat 32QBT (SOLD)
2006 GMC 2500, Airsafe 20K hitch, Air Lift Loadlifter 5000 air bags with Air Lift WirelessONE compressor, EFI Live
Jack of all trades, Master on none
12-21-2016, 07:00 AM
#47
For the best selection and price take a look at Power Equipment Direct.
http://www.powerequipmentdirect.com/
2017.5 Cedar Creek 34RL2
2018 F-350 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
12-21-2016, 07:59 AM
#48
We have the 3100 Champion and have been happy with it. I did notice a little bit of engine hunting the last time I dry camped with mine but it eventually settle down. I do run the blue Sta-Bil in all my fuel can fuel so not sure why it did that. I also run my carb dry when I store my gen for any extended period. Other then that one incident it has started easily and ran my 15K AC unit with ease. My coffee maker hits it harder than AC unit does. I do turn that off to run my micro as the two will throw the overload and then I have to let it cool before it will reset.
2017 Wolfpack 25Pack12
08 Dodge Cummins 6spd 4X4 CC
12-21-2016, 09:46 AM
#49
Originally Posted by TandSH
Where I bought mine (Champoin). Fast service, arrived in 3 days. Best price, no tax (all good). Their 'regular advertised price' is what the 'on sale' price is at most 'brick and mortar' retailers is..... Costo included.
Mine 'hunts' ocassionally as well. I believe it has to do with load sensing more than anything else and a coffee maker is a steady 1500 watt pull whereas your AC pulls pulls hard on compressor start and then drops off when running. Always keep in mind that with any capacitor start motor including cap start / induction run, inrush amperage is 3 times running amperage.
Lots of discussion about weight and being able to 'lift' a unit into and out of say a truck bed or in your unit for transport.
I carry mine inside my truck camper. The Champ is rectangular and has handles integrated into it so it 'fits' nicely inside.
The door height in my TC loaded on my truck is 36" and I'm 67 and I have no issue putting it inside for transit, (mime weighs 65 pounds full of fuel and while that sounds like a lot, it handles easily because of the shape and because it has handles on both ends)
I do like the Champ because it has a double gas shutoff. You can turn it of at the front panel plus the cap gas a positive shutoff built in so no chance of fumes or spillage while it's inside my camper.
Previously, I owned a Yamaha 2800I which was appreciably heavier (79 pounds). I ran it for 10 years and sold it (they do hold their value) for more than I paid for the Champ. I did maintain the Yamaha carefully with regular oil changes (twice yearly), air filter cleaning, carbon removal from the USFS approved muffler and valve adjustments.
Keep in mind that none of these units are maintenance free. The Honda, Champion, Yamaha and all the others require maintenance (other than putting in gas and running them.
All require valve adjustments and decarbonization of the muffler....across all brands, no exception.
If you assume they are all 'plug and play, you'll be in for a surprise, because they are not. If you ignore the necessary maintenance, they will all fail at some point.
Just like your vehicle, they need regular maintenance.
Internally. they are all basically the same. Higher output units have larger components and larger engines, which of course equates to more weight.
IMO (only), It distills down to the best bang for the buck, color or brand name is not important today. They all share the same electronic components, the only mechanical difference is the engine itself and all the brand leaders have advanced OHV engines and safeguards like low oil shutdown.
Knowing what the 'insides' were about, when I replaced my aging Yamaha, I shopped solely on price and portability.
Just my observations... Yours may be different, however, the Honda is no better than the Champion or the Yamaha or the Wen despite perceived notions.
12-21-2016, 10:01 AM
#50
Hi
I have a 3500 watt Powerhouse inverter and if I had a redo I would buy two 2000 watt generators and buy are parallel kit. I cannot move the 3500 watt unit myself and like Filterman I get help getting it in the truck and leave it there for the duration of the trip.
I would always be able to fit one 2000 watt unit in the storage compartment for the whole camping season. I can't do that with the 3500 watt unit.
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
12-21-2016, 10:05 AM
#51
I have 2 2000i Honda's that I parallel, I brought them eight years ago. I think I paid $859 apiece for them, free shipping and no tax. They have been great, I take them on every camping trip I go on. They even come in handy when there is a storm at home and power goes out. But buy what you like and can afford
12-21-2016, 10:33 AM
#52
What has worked for me
Having to power a 15k a/c, a television, a microwave and some lights and outlets in our 5th wheel set me out on my journey.These are the reasons I purchased two Yamaha 2000 watt generators along with a few suggestions. The requirements may not be the same for you.
1. Figure out what you want to run at one time and purchase wattage according to your needs.Remember that your electrical needs may change in the future as you may upgrade your unit.
2. Two individual units are easier to move around than one big one and sometimes we go places (i.e beach, river, etc.) where one generator is all I need.
3. Get units that can be paralleled together. I have a total of 4000 watts and 30 amp available to me with both units paralleled.
4. The Yamaha's were cheaper than the Honda's but not inexpensive by any means. They have a three year warranty and were just as quiet as the Honda's.
5. Check sound decibel levels on all of the units you are considering. Loud generators will get you run out of many campgrounds.
6. Don't get sucked into the brand debate. Your budget will ultimately determine your choice. Get the best you can afford and with proper maintenance, many will give you years of service.
7. Good luck in your quest and Happy Camping.
12-21-2016, 10:44 AM
#53
Misinformation here on some good generators that are overlooked.
I have a Powerhouse 4 kw Fuel Injected generator. This will run at altitude just fine and the tank is large enough to run our 15 k but AC for 8 hours. Remote start as well.
For coffee pot maybe a stove top might be better than timing up a generator for coffee.
Look at Lifan as well, Powerhouse are the same base units imported.
B and B
12-21-2016, 11:05 AM
#54
I purchased the Champion 3100 inverter 2 years ago. It runs my 13.5k ac just fine. I mainly used it for a comfortable quick break while traveling. Just start it up and catch a few hours of cool sleep. Then a hot coffee when you wake.
#55
To me the answer is simple after researching and doing it. You have 2 viable options:
I purchased Choice A after extended research. The only one I found that had a dedicated 30amp RV plug!!!! The generator is specifically designed for RV use. 100% of the power is available at one dedicated 30amp RV outlet. Other generators split output among their outlets and they CAN NOT be combined unless needing 220Vac - which is not combining in the sense everyone is thing off. The only slight negative is it is obviously not as quite as a Honda, but so what. I place it away from the TT for safety anyway. If any noise is a problem, choice B is the solution.
I have not tried Choice B, but it is the Honda equivalent at half the price.
A) Champion Brand Dedicated RV Generators - few models
https://www.lowes.com/pd/Champion-Po...ngine/50436748
https://www.lowes.com/pd/Champion-Po...ine/1000039715
Full List https://www.lowes.com/pl/Portable-ge...ent=1362617603
B) Harbor Freight - I have not tried this item, but for the price it is worth trying as an alternative to Honda at half the price! You can return them if they are no good.
2000 Peak/1600 Running Watts, 2.8 HP (79.7cc) Portable Inverter Generator CARB
I am sure you will receive many opinions (including this one) - review all, try, and decide for yourself.
12-21-2016, 11:38 AM
#56
At 66 db I wouldn't say option B is a good solution to the noise problem. I think both those generators should stay where they belong, at a construction site.
12-21-2016, 11:54 AM
#57
Unfortunately, while the Champion generators you referenced are "R/V ready", they are NOT inverter type generators and prohibited from use in many campgrounds. If you never visit a campground where open frame/contractor type generators are prohibited you'd be OK but most campgrounds won't allow them.
**HERE** is a link to Champion generators that are 'R/V ready' and are also much quieter, inverter type units.
12-21-2016, 12:47 PM
#58
I just picked up a cheap one and through it in the compartment.
it works alright.
12-21-2016, 12:54 PM
#59
As I said, decide after MANY inputs and get the real data. Everybody wants to force their opinion. See Image 61 vs 59 - not bad for $1,000 less.
Also, the 4Kw Champion I had IS, WAS and WILL continue to be Ready until I trade in my TT and get an RV. I run my AC and most anything else as long as I stay under 29amps total. That means start the AC First.
12-21-2016, 01:36 PM
#60
I own the same Champion contractor style generator as yours in the pic.
I would NEVER subject my camping neighbors to its noise level.
It's great for home outages and boondocking where no one is nearby.
But not appropriate for campground usage.
