10-04-2018, 09:05 AM
Generator size
I am sure this has been asked before, searched but can’t find it. What size generator do I need? We don’t really plan on much dry camping, but on long trips for a night or two we probably will (state parks, Walmart’s, truck stops, etc). We will be wanting to run the air, probably tv, water pump. What size is best, what is bare minimum I could “get by with”? Are there different types of units regarding actual power generation? I am just looking for basic numbers, will go bigger than minimum, just need starting point. TIA
10-04-2018, 09:15 AM
gen
I carry 2 Honda 2000's Operate on one until more power is needed. Then parallel them together for 4000 watts max, 3200 watts continuous power.
C.B.
10-04-2018, 09:24 AM
It seems like the going trend is to get somewhere around 3500 watts.
There is a number of ways you can get there. Two smaller units that are Daisy-chained together and easier to lift or one larger unit that is more heavy but all in one.
For me it would depend on how much I felt comfortable lifting and if I had help doing it. For me it would probably be a larger all-in-one system. I'd leave it in my truck and get a longer cable to plug in to my RV.
Some of the units will run on propane too. I think I would look for that feature on a new one.
10-04-2018, 09:43 AM
I’m using a Champion 3400 watt inverter generator. Runs my 15k a/c just fine and is quiet. Can’t run the microwave with a/c though.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
10-04-2018, 10:05 AM
For price and features you can't beat the Champion. I can start the generator and have the air conditioner running without getting out of bed.
https://www.amazon.com/Champion-3100...enerator&psc=1
10-04-2018, 10:28 AM
I also use the Champion 3100. Will run my 15K A/C, tv and lights, but I need to run the fridge and water heater on propane or it's too much draw.
2019 Silverado 1500
No camper, currently
10-04-2018, 10:44 AM
Be sure you get an inverter style generator. The open frame style are much louder, not allowed in many campgrounds.
Cedar Creek Lake, Texas
2019 Keystone Loredo 290SRL
Andersen hitch
10-04-2018, 10:57 AM
Looking to buy one...I'm hoping it will run my 15k a/c...Could you tell me the elevation that you run it at? Thanks..
Dave...Northern Nevada
2018 Rockwood 8299bs
2007 GMC 2500HD Diesel SLT short bed w/gravity flow75 gallon Fuel Tank.. Cat delete
Firestone Airbag Ride Rite system
10-04-2018, 11:00 AM
several things to consider: if you don't 'think' you'll really be 'off-grid' more than a night at a time, and only very infrequently, then why even bother with the storage, fuel, and sound issues of a generator?
- your TV may already work off your batteries, if it is a 12v type. Your water pump certainly does, as all your lights. Any rv fridge will also work off of 12v and/or propane, as well as your water heater.
- a small Power Inverter, off the shelf at W*mt and other places can easily power your TV, if it is 120v.
- carrying fuel now becomes as issue... where to carry it/store it, how much, etc.
- what 'size'? that's totally up to you... but if you are really trying to power an air conditioner, even by itself, it will need to be 'sizable', and not easy to handle.
I would suggest not jumping into the generator thing right at the start. Take some trips. Find out how you 'really' camp. It temperate whether, you may not need AC, so it becomes much easier - only the TV could be a question. For a quick overnight just 'every now and then', it's probably overkill to carry around a generator and fuel just for those 'rare' scenarios, especially if you really are most always at electric hook ups where you travel.
The Turners...
Research micro-air easy start for your A/C and you might be able to get by with only one generator (2000 watt). I run a Honda Eu2200 and have the easy start...runs my A/C no issues. Agreed that I can't run the micro and A/C at the same time.
m
2014 Flagstaff Shamrock 21SS
2018 F-350 Crewcab Lariat 4x4 6.7 powerstroke
Deputy Fire Chief-09-11-2026 retirement!!!
10-04-2018, 12:21 PM
Below 1500’.
Lee and Anne
