04-03-2016, 11:29 PM
Generator Talk
Hello,
I currently have a Generic LP 5500 generator which is super loud that was mainly purchased to backup my house if I lost power. I was going to use this to power my 18' work and play but after hearing how loud it was I don't think the Generic is feasible. I know a guy who has a Honda EU3000is and he uses it to power his 28' trailer and I fell in love. I was looking for some advice as to what I could get by with as far as an overnight generator. Would 2000 watts power the trailer in the middle of winter or should I look for the 3000 watt plus models. Thanks
2005 Dodge Ram Cummins, QCSB, 4x4, SB 3250 Multi Friction dual disk clutch, NV5600, 35/12.5/17, Carli Suspension, Top Gun Control Arms, Amsoil 6080, Pusher horn, 2nd gen man, SSR, Gauges, HID's
04-04-2016, 12:50 AM
A 2000w inverter generator will run everything but the a/c.
04-04-2016, 12:53 AM
Thank you for responding. This is the exact type of info I was looking for. Do you think the 3000 watt model will run the AC? I don't want to purchase a unit that won't do the job.
04-04-2016, 01:10 AM
Can't say without knowing what a/c you have and its BTU rating.
If it's a 13.5k, 3000w should.
If it's a 15k, maybe.
04-04-2016, 03:13 AM
Follow the lead of the guy with the "Honda 3000is" that you fell in love with! Youroo!!
04-04-2016, 04:57 AM
There are two different Honda 3000 generators, Check actual nameplate rating. One has 3 more amps of current
3000is is more
. http://powerequipment.honda.ca/compa...3000iskc_10399
B and B
04-04-2016, 10:15 AM
I have a Yamaha EF3000iseb and it will run everything just fine. Purrs like a kitten!
Humteddy2
2014 Silverado LTZ
2016 Surveyor 285IKDS
Humteddy
2017 Surveyor 285 IKDS
2016 GMC Sierra Denali HD 2500 Duramax
04-04-2016, 10:33 AM
Just to muddy the waters as you seem primarily concerned about cooler weather use. Another option is two 2000 series generators in parallel. When you do not need AC, you only take one. Much lighter to carry around and unless the AC is used on most of your trips, you only need to take one.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-04-2016, 10:38 AM
Seems like he "OP" ask also about running the AC! This was post # 3! Youroo!!
04-04-2016, 03:31 PM
You may want to consider the Yamaha 3000iseb. It will run a constant 2800 and supply an extra 500 for 10 seconds. This will ensure that the ac will fire up. Honda currently doesn't have the 500 boost.
04 Ram 3500
07 Ram 3500 X2
10 Ram 3500 Laramie
2011 Puma 295kbh
04-04-2016, 04:03 PM
Left Coast
If you have a Progressive surge protector hard wired in, the Yammy won't work....and the Honda needs a grounding plug ($2.00)
04-04-2016, 05:38 PM
But the Honda will?
04-04-2016, 06:02 PM
Dometic recommends minimum 2500 watts for all there a/c units
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
04-04-2016, 06:29 PM
Left Coast
Yep....2 2000i in parallel
04-04-2016, 06:58 PM
Is it okay for the generator to get rained on?
