Old 04-16-2019, 07:13 PM   #1
Generator to shore power
In our model sandpiper 2005 going from shore to generator or reverse do we have to do anything special. We did not get any manual with our 5th wheel just a quick walk through how to start up shut off ect from formal owner.
Grant56 is offline   Reply With Quote
Old 04-16-2019, 07:21 PM   #2
you may or may not have to. do this. unplug from shore power and start the generator. wait a couple of minutes and see if you have any 120 vac power. if you do you'e set. you have an automatic transfer switch. if not you may have to plug the shore power cord into a receptacle somewhere the 5th wheel to have the shore power cord receive the generator output. the receptacle would look identical to the receptacle that you plug the shore power cord into on the pedestal.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 04-16-2019, 07:34 PM   #3
kenandterry's Avatar
X2 describing auto transfer versus manual transfer.
But if you do have to plug into a receptacle inside your rig, turn OFF the generator before plugging in, the restart the genny.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 04-16-2019, 07:54 PM   #4
Thank you
Old 04-18-2019, 07:41 AM   #5
First, I have NO experience with RV generators. But, I do have some amount of residential generator experience.
Your main concern should be that you do NOT (under any circumstances) back feed power in to the park's system. IF the park is experiencing an outage (or just crappy power that you don't want to deal with), you can expect that someone somewhere is working to get it back. You do not want to put power to a line that is expected to be dead. Lineman SHOULD be checking for voltage, but you don't know.
xd40c is offline   Reply With Quote
Old 04-18-2019, 08:10 AM   #6
bubbles's Avatar
You're right. You have no experience with RV generators.
Old 04-18-2019, 08:27 AM   #7
That was crude.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is online now   Reply With Quote
Old 04-18-2019, 08:35 AM   #8
A lineman thatís not taking the proper safety procedures needs to get some insurance so his next of kin can bury him. I have a home generator that I have backfed, you are supposed to have a double pole throw but I donít have room for that so I just have the main breaker that I pull
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 04-18-2019, 10:26 AM   #9
bubbles's Avatar
Originally Posted by CedarCreekWoody View Post
That was crude.
Probably so but he was interjecting false concerns to an apparent newbie. A lot of posters take what they read as gospel. That's how newbies sometimes become confused and then pass on to others what they have read; be it right or wrong. I probably have done this myself.
Old 04-18-2019, 10:29 AM   #10
The auto transfer switch prevents this from happening . if you have to do it manually then again it won't happen
MR.M is offline   Reply With Quote
generator, power, shore power
