Can you access the area under your entrance steps?
On the wall directly in front of you, beside the BCC ( Battery Control Center) you should see a black square relay trip breaker. Look,carefully, and you might see the trip arm exposed out at a 45 degree angle.....looks like a little stub.
That will trigger if you use the jacks or slides with weak batteries.
Push it back in and you should be good to go.
Engine running for hydraulic jacks.
Generator running or plugged in a campground for powering the slides will help the batteries under the steps.....they need to be really strong.
Ken and Terry
