Old 03-12-2013, 11:09 AM   #11
Herk7769's Avatar
While this discussion is about 5th wheels; the same applies to travel trailers.
The only big difference is the percent of payload allotted to tongue weight 10% - 15% (not 15% - 25%).
320RS Dry weights with accessories
HAM CALLSIGN - KC3FFW
Old 03-12-2013, 11:16 AM   #12
Awesome, thanks for the info! I will run out and get it weighed before I commit to buying the 23LB.
hellerbrewing is offline   Reply With Quote
Old 03-12-2013, 11:19 AM   #13
TURBS's Avatar
Remember truck needs to be as it would camping
Passengers
Fuel tank full
Wood
Bikes
Gennie
Tools
Coolers
Etc etc etc
Good luck. Let us know .
Turbs
Old 03-12-2013, 11:40 AM   #14
One caution: The Flagstaff 23LB can have the optional Murphy bed. If your 23LB has the Murphy bed the hitch weight can be alot higher than listed in the specs. Also need to account for weight of the WDH head (you will need one) My E2 Equalizer weights about 75 lbs for example.
Roy & Jean
2010 Rockwood mini Lite ETC 181
2002 Toyota Tundra 4.7l 4x4
Prodigy P3, E2 WDH
rschoono289 is offline   Reply With Quote
Old 03-12-2013, 12:17 PM   #15
The one I will be getting does not have the murphy bed. I am opting for the extra storage space. But I guess this could load up the tongue weight as well. I'll have to be careful where I put the heavy stuff.
I was going to if the dealer would give me a discount on the WDH. I looked at the Equalizer on Amazon and was going by their weight of 100lbs. Good to know that it is somewhat less than that. I was also looking at the Anderson 3380. It sounds like it is fairly easy to install and has really good reviews (they could be bogus I guess). Anyone have experience with these? Does it matter that much which one I get or do they all perform about the same?
As far as weighing, I was thinking I would load up the family and fill up with gas to see how much I would have left over. Being that this is my first camper, I am not real sure what all I am going to need. I suppose I can load some the suitcases with dirty laundry, throw some firewood in the back and maybe a cooler full of frozen meat. Maybe the camping equipment I have in the garage. This should give a fairly accurate picture.
Old 03-12-2013, 12:58 PM   #16
rschoon, are you happy with the equalizer? Does it make any popping noises when you turn?
Old 03-12-2013, 05:02 PM   #17
Excellent idea to weigh your TV. Usual limit is the payload on a 1/2 ton. We did a 4750km trip our first year to east coast returning thru east USA. The E2 did a good job of balancing the weight and reducing sway. The curb weight of TV includes full tank of gas and driver (150lbs). i.e. my 2002 Tundra curb was 4518 and GVWR 6036 so payload roughly 1518. But loaded for trip TV = 5542, so payload drops to 494. (available for trailer hitch weight). In my case I travel with a disability scooter about 100 lbs also have tonneau cover on TV. Easy to see how the payload gets consummed. Always good to get actual weights. I used the local dump scales to get low cost weigh in. Best of luck in your travels. btw the 23LB is terrific TT and will give you good service
Roy & Jean
Prodigy P3, E2 WDH
Old 03-12-2013, 05:20 PM   #18
forgot to answer your question on noise from WDH. All of the WDH make noise as they are based on friction (metal to metal interface). You dont need to remove the bars when backing into site using the E2. But they will make noise during low speed turns.
Roy & Jean
Prodigy P3, E2 WDH
Old 03-12-2013, 08:14 PM   #19
Ok, so I loaded up the kids, dirty clothes frozen food and some other miscellaneous items. I took it down to the scale and I get 3280 on the front and 2580 on the rear giving me a total of 5860. That leaves me with with about 640 lbs for the tongue weight and the WDH head. Fully loaded I would be pushing it I guess. On the bright side, I think I have about 1000 lbs left on the rear axle rating. You guys think this is cutting it too close?
I talked to the dealer and they will install a A Reese Pro Series 4 control arm (dual friction sway bars) hitch for $400. An equalizer 4-point hitch would run $800 but he said their shop recommends the Reese.
I think it is similar to one of the bottom 3, except with another friction bar.
Trailer Hitches, Hitch Accessories, Hitch Wiring
Old 03-12-2013, 08:26 PM   #20
Herk7769's Avatar
This means something ONLY if you do not exceed the GVWR of the truck. Not breaking your rear axle will be small comfort when you crack your frame.
