Old 07-14-2017, 09:38 AM   #1
rp53's Avatar
getting rid of the China bombs
put 4 goodyear endurance
ID:	144727Click image for larger version
2017 Micro Lite 21FBRS (sold)
2019 GMC Sierra 2500 HD extra cab Z71
looking for the perfect 5er over the winter
rp53 is offline   Reply With Quote
Old 07-14-2017, 09:56 AM   #2
Did this myself 2 weeks ago. Hopefully it's a good tire. Date stamp on them puts them made in May and June. I like that.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
dwayneb236 is offline   Reply With Quote
Old 07-14-2017, 11:10 AM   #3
rp53's Avatar
we'll see it seemed to ride better on the way home, leaving in a couple of hours first weekend trip with them no phone or WiFi let you know how it feels when i get back
Old 07-14-2017, 11:18 AM   #4
I'm actually leaving on a trip tomorrow so I'll be trying them out this weekend as well.
Dwayne and Susan
Old 07-14-2017, 11:19 AM   #5
rp53's Avatar
cool!
Old 07-15-2017, 02:49 AM   #6
Big1's Avatar
I went to discount tire the other week to check on some but decided to wait until we come back and get some next year.
2018 Dodge Ram 3500 6.7L CTD
2019 Jayco Eagle 321RSTS
Retired Army MSG.
Big1 is offline   Reply With Quote
Old 07-17-2017, 10:02 AM   #7
rp53's Avatar
maybe it is a mental thing but the TT seemed to pull much better, with the new tires and it was much more pleasurable not worrying about having a blowout. they also must have less drag than the castle rocks as on the last trip i avg. 11.7mpg and this one 13.2mpg.
Old 07-17-2017, 10:24 AM   #8
Attachment 144727Attachment 144727
Good call on Tire change,I can't tell by Pic but what did they place the "Jack" on under the unit? Youroo!!
Old 07-17-2017, 01:06 PM   #9
rp53's Avatar
they used 4 2 ton jacks 2 per side 1 under each axle
Old 07-17-2017, 09:32 PM   #10
Dexter axle says Never jack on the Axle of the "Torflex axles",only the Frame! Youroo!!
Old 07-18-2017, 04:06 AM   #11
rp53's Avatar
didn't know that
Old 07-18-2017, 06:16 AM   #12
didn't know that
Yes,Axle Tube is very thin and Hollow! Also "Jacking/Lifting " on it could change the "Camber" that is Built into the Axle! Frame or Ramp lifting is the Only recommended way to "Change a Tire/Wheel or perform Maintenance" on swing arm Tube axles! Youroo!!
Old 07-18-2017, 06:19 AM   #13
rp53's Avatar
well let's hope they didn't screw it up
Old 08-28-2017, 10:17 AM   #14
rp53's Avatar
quick update, have had 4 trips with the new tires, i really like them, my gas mileage seems to have improved if you can call 1.7mpg better on average an improvement. the TT seems more stable on the road, wind from big trucks don't seem to be a problem any more and last but not least, yesterday after 110 mile trip home it felt the tires as soon as we stopped (not a tec guy don't have a temp. gauge.) however the tires were cool to the touch, heck the spare tire was warmer. this really surprised me.
and to youroo apparently they didn't screw up my axles as i am showing no wear as of yet that makes me happy and thanks will not let that mistake happen again.
Old 08-28-2017, 10:31 AM   #15
jeff64's Avatar
I changed my st205 75R- 14 Constancy "C" over to GY Endurance of same size ( less than 2" clearance between tires) early this spring and also noticed about .5 mpg increase. What I did notice however, was that things that I normally left in place moved around at 65psi because of the stiffer ride. I cut the air back to 60 psi and I don't seem to get quite the movement inside the TT. I changed them out myself and repacked the bearings and all are running nice and cool
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
Old 08-28-2017, 11:24 AM   #16
41ford's Avatar
I have read my manual quite few times, but never have read anything about not placing a floor jack under the axles to raise the tires.
I will download the electronic version of the manual and do a search within.
BTW, smart move to remove those Chinee Maypop tires. Hope you installed a TPMS with those new tires.
Eventually, one of these days the manufacturers are going to install premium tires and a TPMS on all of their trailers as standard equipment.
JR
2016 Forest River Heritage Glen 276RLIS
2017 Chevrolet Silverado LTZ 2500HD Duramax
Pasco, Washington
41ford is offline   Reply With Quote
