Old 10-12-2015, 09:55 AM   #1
Glowstep Revolution
Just installed the Glowstep Revolution by Torklift. I had wanted something that when you are on those sites that you need an extra step and with the adjustability of these it seem to fit the bill. The install was pretty straight forward, I unbolted the factory set and raised these up to bolt in. The instructions say you might have to cut your factory bracket and I did not want to do that. There was one bolt in the rear that was hitting. I ended up just removing it until it was mounted and drilled a hole for that bolt through the factory bracket. We just got back from a trip and I enjoyed the steps very much, with the adjustable feet they are very sturdy on uneven ground. The site was had a wide pad so I havenít got to test the height adjustability yet but can see with the three different heights it should work well for all sites.
ID:	91302   Click image for larger version
Hornnumb2 is offline   Reply With Quote
