Originally Posted by CaptnJohn
Length is not a problem, mine is a few " under 43'. My 5er has a gvwr of 15,200#. We load heavy and still do not come close to the 3450#CC. PW is around 2880#. 2016 F350 SRW scales fine on all numbers. After 1 dually (not so affectionately named PIA) I'd never buy a 5er that required one. At 17K you would definitely in dually territory I believe.
Ya, length and trailer weight is not a problem. For me, it's the cargo capacity. I've got the 50 gallon Titan tank vs 26gal stock tank, so that's an additional 170lbs, plus I've got the Pullrite Superglide for another 250lbs+. So I've got over 400lbs of my cargo capacity already taken up.
What model truck do you have? I only see a couple models (2wheel drive) that have 3400+ lbs of cargo capacity.
del Wheelbase 6.2L 6.7L 6.2L Std./Opt. 6.7L Std./Opt.
F-250 Super Duty (1)
4x2 Reg. Cab 137.0" 10,000 10,000 3,806/ 3,115/
4x2 SuperCab 141.8" 10,000 10,000 3,024/ 2,347/
4x2 SuperCab 158.0" 10,000 10,000 2,926/ 2,184/
4x2 Crew Cab 156.2" 10,000 10,000 2,812/ 2,148/
4x2 Crew Cab 172.4" 10,000 10,000 2,707/ 1,975/
4x4 Reg. Cab 137.0" 10,000 10,000 3,396/ 2,703/
4x4 SuperCab 141.8" 10,000 10,000 2,625/ 2,000/
4x4 SuperCab 158.0" 10,000 10,000 2,523/ 1,793/
4x4 Crew Cab 156.2" 10,000 10,000 2,426/ 1,792/
4x4 Crew Cab 172.4" 10,000 10,000 2,312/ 1,586/
F-350 Super Duty (1)
4x2 SRW Reg. Cab(2) 137.0" 10,000 10,500* 3,694/ 3,548/3,048
4x2 SRW SuperCab(2) 141.8" 10,000 10,700* 2,956/ 2,981/2,281
4x2 SRW SuperCab(2) 158.0" 10,200* 10,800* 3,087/2,887 2,948/2,148
4x2 SRW Crew Cab(2) 156.2" 10,200* 10,800* 2,973/2,773 2,911/2,111
4x2 SRW Crew Cab(2) 172.4" 10,500* 11,100* 3,139/2,639 3,038/1,938
4x2 SRW Reg. Cab(3) 137.0" 10,500 11,000 4,152/ 4,007/
4x2 SRW SuperCab(3) 141.8" 10,500 11,000 3,414/ 3,239/
4x2 SRW SuperCab(3) 158.0" 10,900 11,500 3,745/ 3,606/
4x2 SRW SuperCab(3) 158.0" 11,400 / 3,506/
4x2 SRW Crew Cab(3) 156.2" 10,700 11,400 3,432/ 3,470/
4x2 SRW Crew Cab(3) 172.4" 11,000 11,500 3,598/ 3,397/
4x2 SRW Crew Cab(3) 172.4" 11,400 / 3,302/
4x2 DRW Reg. Cab 137.0" 13,500 14,000 6,829/ 6,682/
4x2 DRW SuperCab 158.0" 13,900 14,000 6,381/ 5,733/
4x2 DRW Crew Cab 172.4" 14,000 14,000 6,255/ 5,513/
4x4 SRW Reg. Cab(2) 137.0" 10,400* 10,800* 3,681/3,281 3,428/2,628
4x4 SRW SuperCab(2) 141.8" 10,500* 11,100* 3,068/2,568 3,024/1,924
4x4 SRW SuperCab(2) 158.0" 10,700* 11,200* 3,185/2,485 2,946/1,746
4x4 SRW Crew Cab(2) 156.2" 10,600* 11,200* 2,988/2,388 2,926/1,726
4x4 SRW Crew Cab(2) 172.4" 10,800* 11,200* 3,075/2,275 2,734/1,534
4x4 SRW Reg. Cab(4) 137.0" 11,300 11,500 4,501/ 4,053/
4x4 SRW Reg. Cab(4) 137.0" 11,400 / 3,958/
4x4 SRW SuperCab(4) 141.8" 11,100 11,500 3,593/ 3,351/
4x4 SRW SuperCab(4) 141.8" 11,400 / 3,256/
4x4 SRW SuperCab(4) 158.0" 11,000 11,500 3,410/ 3,174/
4x4 SRW SuperCab(4) 158.0" 11,400 / 3,079/
4x4 SRW Crew Cab(4) 156.2" 11,300 11,500 3,613/ 3,148/
4x4 SRW Crew Cab(4) 156.2" 11,400 / 3,053/
4x4 SRW Crew Cab(4) 172.4" 11,200 11,500 3,400/ 2,959/
4x4 SRW Crew Cab(4) 172.4" 11,400 / 2,864/
4x4 DRW Reg. Cab 137.0" 13,800 14,000 6,712/ 6,262/
4x4 DRW SuperCab 158.0" 14,000 14,000 6,070/ 5,330/
4x4 DRW Crew Cab 172.4" 14,000 14,000 5,852/ 5,112/
