Old 08-11-2016, 12:49 PM   #11
cj5thwheel's Avatar
The load capacity on my rims are 3200 OT tires on my trailer work 80 pounds I'm running the g614 because I am tired of Chinese tires you never know when they'll blow out I might be overcautious but I'd rather be that way
cj5thwheel is offline   Reply With Quote
Old 08-11-2016, 03:05 PM   #12
bscottroberts's Avatar
I always run my trailer tires at Max PSI rating.
Flat Deck trailer has Load E- run them at 80.
Toy Hauler with Load G(G614)- run them at 110.
2006 34FK Work and Play
2016 Chevrolet 3500 Duramax DRW
bscottroberts is offline   Reply With Quote
Old 08-11-2016, 03:46 PM   #13
Send a message via MSN to redjet
You installed G614 tires for safety reasons and they should be inflated to 110 psi. Just because your camper weighs 15000# doesn't mean the weight is evenly distributed across the axles. I have a 2016 Cardinal that weighs 14000# dry, but it weighs considerably more on the left side (as opposed to the door side). The reason it weighs more on that side is because the slideouts run almost the full length of the fifth wheel. In addition, cabinets run the full length with a large pantry, all appliances (inc. Residential ref), TV, fireplace, most of king bed and other storage are also on that side. Door side - slideout for dinette and TV lounge, bathroom and that's about it. Bottom line - unless you have weighed the load on each side of the camper and know the weights for sure - inflate to max load rating. I replaced the Goodyear Marathons that came on the Cardinal with the G614 for the same reason, as you. Yes, I run them at 110 psi.
2016 Camping - 181 days
2017 Camping - 111 Days
2016 Cardinal 3850RL - 7/31/15
2015 Ford F250 - 6.7L - King Ranch - 4X4 - Air Lift 5000/ wireless air
redjet is offline   Reply With Quote
Old 08-11-2016, 04:42 PM   #14
Havasu Bill's Avatar
I run mine at 110 to get the full rating out of them. I just feel safer that way and the 5er tows and handles fine with that pressure.
Havasu Bill is offline   Reply With Quote
Old 08-11-2016, 05:22 PM   #15
Airdale's Avatar
The OP is limited by the specs on his rims. I suspect someone told him it would be much better and provide more protection if he used a higher load ranged tire. Which is true, provided the rims are speced for the tires. There is no advantage buying a LRG tire then using it as a LRE.
At the very minimum the replacement tire must provide a load capacity equal to the OE tires via inflation.
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15139
Airdale is offline   Reply With Quote
Old 08-11-2016, 07:16 PM   #16
Here it goes again on tires. cj here is how I interpret your question and answer. I also have an engineering background but do know when to compromise. I have been in exactly your situation except none of my tires were loaded beyond 2700 lbs. On a 2013 trailer I had 2 blowouts on Towmaster at 1 1/2 years and bought a set of Marathons when broken down and had a failure at 1 year with those tires. I was done with st E tires running at 90% of rated load and only rated at 65mph. I bought g614s knowing that I only had 6 inch 3200 lb rated wheels. Higher rated 6 hole 6 1/2" wheels on a 6000lb axle is a rare thing. There is another "expert" named tireman who talks about shear in an under inflated tire. He makes sense so I have chosen to inflate my tires to 90 psi which equates to the 3200lb load rating of the wheels. This matches GY inflation guidelines and offers a very safe load margin with overly built tires. I used to watch my stE tires in my rear view mirror on backing and they were so torqued it was frightfull. Watch how your 614s perform. While not scientific it is an indication of shear resistance. We are not gaining any load capacity but are getting a superior tire that should not tear up the side of our trailer.
palmetto rogue is offline   Reply With Quote
Old 08-12-2016, 07:40 AM   #17
cj5thwheel's Avatar
Thank you I appreciate all the information I know now what I have to do I will run the tires at 90 PSI and I will be safe like I said my rims are rated at 3200 my trailer is 12000 unloaded so I will feel safe at 90 PSI again like I said thanks for all the info
pressure, tire
