Old 08-10-2016, 09:22 PM   #1
cj5thwheel's Avatar
goodyear G614 tire pressure
Do you have to run 110 PSI in this tire .My 5thwheel weigh 12000. Loaded 15000. My wheels rated 3200. can I run them at 80 PSI or 90 Psi thanks cj
cj5thwheel is offline   Reply With Quote
Old 08-10-2016, 09:30 PM   #2
I run mine at 105lbs
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 08-10-2016, 09:36 PM   #3
cj5thwheel's Avatar
I don't want to over inflated or under-inflated
Old 08-10-2016, 10:01 PM   #4
I keep mine at 100 psi. My Vengeance weighs around 17,000 lbs. or so loaded down on triple axles.
But I think I read recently that running them at 80 psi is not a problem if the wheels aren't rated.
2015 F350 6.7L Lariat CC LB (for sale)
2016 Vengeance Touring Edition 40D12
Former Forest River Campers:
2004 Puma 30FQSS
2010 Sabre 31QBDS
2014 Work & Play 30WRS
KFX450RXC is online now   Reply With Quote
Old 08-11-2016, 08:04 AM   #5
extremebike's Avatar
Here is what Goodyear says in the inflation guide.
http://www.goodyearrvtires.com/pdfs/rv_inflation.pdf
regards,
Extremebike
2004 Ford F550 6l Lariat SuperCrew, Fontaine Bed,
Link Systems Air Ride
2011 Sterling 32RL with Michelin XPS tires
extremebike is offline   Reply With Quote
Old 08-11-2016, 08:35 AM   #6
cj5thwheel's Avatar
Thanks a lot for the comeback on the pressure I think I'll run then at 85 PSI
Old 08-11-2016, 08:35 AM   #7
cj5thwheel's Avatar
Goodyear says with my wheels I can run them between 85 and 90
Old 08-11-2016, 10:37 AM   #8
Airdale's Avatar
What does your wheel manufacturer say about that? Their name is on the wheel, email them about load capacity and inflation pressures.
Are the rims rated for the high capacity GY tire? Are they 6.5" wide?
https://www.goodyeartrucktires.com/t...13922909900000
USN - RET
DOD - RET
SSA - RET
Airdale is offline   Reply With Quote
Old 08-11-2016, 10:48 AM   #9
Airdale's Avatar
You have to provide all the details about your original tires and then ask questions about replacements for them.
The bottom line for replacement tires is for them to have a load capacity equal to or above the OE tires. When using tires from another design or size the load capacity is achieved with inflation pressure. 80 PSI on the G614 tire = 3042# of load capacity.
If your trailer had OT tires sized LT235/85R16E your in the ballpark with the G614s, but, you are wasting a lot of money on tires that are just going to provide the same load capacity as the OE tires.
USN - RET
DOD - RET
SSA - RET
Old 08-11-2016, 11:06 AM   #10
I looked at the tables and for mine is 110lb
pressure, tire
