Old 11-14-2012, 07:26 PM   #11
Looks like you did a nice job covering the trailer...This was our first year with the Adco cover. We're pleased with the quality of the cover and hopefully, we were able to get all of the sharp edges covered to prevent any damage.
TravelTracer
2014 F150, Supercrew, 3.5L Eco-Boost, 3.73, Max Tow
2012 Prime Time Tracer 2670 BHS
TravelTracer is offline   Reply With Quote
Old 11-15-2012, 08:12 AM   #12
I just bought the same exact cover for my TT and it is well made. It is breathable and has side vents and looks like it will be a great investment. I like the lil toss across weights clips Adco included to make a one man operation easier. I may have to snug the cover up a bit I have noticed wind bellowing underneath it a lil bit.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 11-15-2012, 06:47 PM   #13
The included weight clips made things easier. My wife, on one side of the trailer, would toss the weighted clip across the ground beneath the trailer to me, on the other side. Simplified things greatly!
TravelTracer
Old 11-15-2012, 07:15 PM   #14
I know we found the weights after struggling throwing the snaps under
Grey9712 is offline   Reply With Quote
Old 11-15-2012, 07:23 PM   #15
I've looked at this thread but still don't know if its good or not to cover a TT over the winter. We live in Western Michigan where winters can be long and cold. We also just purchased our first TT (F.R. Roo) this past summer. Historically we have always kept our pop up camper I the garage so we haven't had to concern ourselves with outdoor storage or the need to cover it. I'd welcome any info on the pros and cons of covering a TT in winter conditions that produce cold weather and a lot of snow! Thanks
Patersoc58 is offline   Reply With Quote
Old 11-15-2012, 11:36 PM   #16
geefhoust's Avatar
I live in Ohio and had the same concerns last year as what your having now. I heard some say that the cover can cause damage to your paint while others never had any problems with their covers. I bought the ADCO cover last year and covered my Mini-Lite. I couldn't be happier with that decision.
I padded all sharp corners and cinched the straps down tight and didn't have the first problem with the cover or the TT. This year I had an RV carport put up and then closed in the back and one side myself, but I still put the cover on just for the added protection. There's no way that I could be happy leaving my TT sit outside without covering it. This is just my opinion so take it for what it's worth.
2016 Ultra Lite 2905SS
2014 Chevy Silverado 2500HD
geefhoust is offline   Reply With Quote
Old 11-25-2012, 02:35 PM   #17
paulmac's Avatar
Can't tell from the pictures. Looks like you did a great job, but does the camper have downspouts? If so hopefully you protected the cover from them. Last year we covered our camper for the first time and by spring we had holes where the down spouts are on one side (more exposed side, more wind). This year we wrapped the down spouts with bubble wrap, some people use tennis balls with an X cut into them and place them over the down spouts. Our ADCO cover works great. Helps protect the camper during the winter, helps keep it clean, protects the roof, etc.
paulmac is offline   Reply With Quote
Old 11-25-2012, 04:04 PM   #18
We put the tennis balls on our downpouts...cut the "X" on the tennis ball and cut a hole in the bottom of the ball to allow for any drainage. Since this was our first time, it'll be interesting to see how the cover worked when we remove it next Spring.
Traveltracer
Old 11-25-2012, 06:05 PM   #19
Dallas Texas
TexasBBQ's Avatar
I've also heard about some damage due to rubbing. Thatís why I went with the Goldline cover rather than the Adco. I've read too many complaints about the Tyvek on the Adco's doing this type of damage. But for every complaint about Adco I read a positive review. Anyway, I decided to go the Goldline route due to that and the warranty. Adco Designer series is 2 yr verses 5yr for Goldline.
Like Traveltracer I use tennis balls and noodles with a little piece of duc tape.
ID:	21816   Click image for larger version
ID:	21817   Click image for larger version
ID:	21818   Click image for larger version
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 12-14-2012, 02:21 PM   #20
RalphieAdie's Avatar
We just bought our 5th wheel in the Fall and just purchased our cover with a new Adco cover. Covered the downspouts with tennis balls, and padded the steps with an old noodle. It was a bit of a challenge being up on the roof and trying to figure out the front and the back of the cover and unravel it for the first time. The whole process took about an hour or so to get it down and secured in place.
We have pine trees which drop sap and needles at various times of the year. Also, the hardwood mulch releases little black spores, which LOVE to attach themselves to any surface. So, having the cover was a no brainer for us.
Ralph & Adrienne
2016 Flagstaff 8528CKWSA
2012 GMC Sierra 2500HD 6.0L
RalphieAdie is offline   Reply With Quote
