Old 10-15-2008, 10:54 AM   #1
Gray-mold spots on white rubber trim
Anybody have a method for removing gray-mold spots on the white rubber exterior window trim (& on white plastic exterior handles)?
I haven't tried any thing like a bleach (Tile-X) or Oxy-clean yet.
I don't want to harm the rubber.
thanks in advance,
Jeff
JeBa is offline   Reply With Quote
Old 10-15-2008, 12:16 PM   #2
powerboatr's Avatar
we use bon ami, not comet or any other cleanser,
bon ami is real fine and doesnt scratch
also had good luck with soft scrub
rinse real well when done then wash the rv to ensure all the cleanser is washed away.
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 10-15-2008, 03:24 PM   #3
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Might also try Bartenders Friend
dimurrrw is offline   Reply With Quote
Old 10-15-2008, 08:46 PM   #4
Question to all on this matter, once all of the mold and stains have been removed is there something one could apply to the rubber surface to keep it from coming back?
Old 10-16-2008, 07:59 AM   #5
I'd like to know as well. I've fought this on every RV I've had.
I have and do use bleach (50/50 with water) to clean them though and have never had an issue. But that's me. Use it at your own risk.....
aintgotnun is offline   Reply With Quote
Old 10-21-2008, 10:07 PM   #6
This thread is diving me crazy, my brain is spinning in my head and I keep coming back to it. There is a lot of knowledge on this Forum and maybe with everyone's ideas we just might be able to come up with a solution. This my Idea and experienceses: I know for a fact that white plastic or rubber is not ultraviolet resistance, it will break down very rapidly, black plastic or rubber is more durable and will with stand ultraviolet rays for a longer period of time. Example: Look at your A/C unit that is out side that's called the condenser, you will see two copper lines, one is small in diameter and the copper is exposed the other on is larger and is insulated. They both should run right next to each other along with the thermostat wire, all three components are held together with cable straps, because these three components are out side in the elements the cable straps should be black, if they are white and have some age on them then they are most like starting to break down some may have a yellow tint and powdery look. When white plastic or rubber breaks down it becomes powdery, if you take a damp dark rag and go over the rubber area before washing your camper you might fined that the rag will pick up a white residue form around the windows or any where else. Once the residue is removed the surface is now very porous and will allow dirt and moisture to settle in the nooks and crannies and in bed themselves deep in the rubber, then the next thing you know you are cleaning the crap out of it with chemicals and or a brush which I believe maybe making matters worse then leaving it unprotected. This is what I am going to try, once I get the discoloration off, then I am going to apply a small amount of Vaseline around the windows to see if it will soak in. The reason for this madness is because this is something I do every year two time in the season with all of the rubber seals on my swimming pool filter system. I have the same seals on the filter that I started with in 1985 and have not replaced one yet and of course I do not have any leaks at this time. The seals are black but they are exposed to chemicals and chemicals dry out rubber seals. Vaseline repels water and chemicals from reaching the rubber surface. So why not try this on the white rubber on an RV? other wise it all will have to be replaced. Please I welcome the Pros and Con's and more suggestion. Maybe we all can pull together and get some kind of solution to help everyone with this ugly mess. One other thing, have you notice that the rubber around the windows where they are pieced together are shrinking and are leaving gaps between each other?
Old 10-22-2008, 08:25 AM   #7
Head Rambler
While that's not a bad idea, I'm afraid it will collect tremdous amounts of dust.
I use Turtle Wax Ice liquid polish. It works great on the fiberglass as well as the plastic and rubber parts. The biggest bonus is that it's super easy to apply and requires no buffing. It has UV stabilizers to help the weathering.
As for the incredible shrinking trim, it's easily replaced.
Here's one place that carries many styles and colors. Vinyl Insert Trim
I've seen RV's where the trim has shrunk leaving 3 to 4 inch gaps.
Salem 29RKSS Pushing a 2500 Mega-Cab CTD!
Gotta go campin!
Old 10-23-2008, 06:06 AM   #8
I use Meguiars mirror glaze cleaner wax on the RV and vehicles, but I don't use it on plastic and rubber.
Old 10-24-2008, 10:19 PM   #9
welshman599's Avatar
Send a message via MSN to welshman599
The deteriation caused by UV is an issue I've been dealing with too; I opted for Armor-All instead of wax for all those plastic and rubber surfaces. It has UV protection and seems to keep the plastics pliable for a lot longer. I tried it on a white ziptie and it held up much longer than untreated, so I figured it would be good.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
