Old 05-31-2012, 01:59 PM   #1
Graywater question
I only have sink drain on popup. My question is at full hookup sites can I drain gray water straight into the sewer hook up or do I have to collect and dump at dump station?
Stevelitt is offline   Reply With Quote
Old 05-31-2012, 02:00 PM   #2
TURBS's Avatar
Yes you can drain grey into sewer hose
Old 05-31-2012, 02:25 PM   #3
Barney1's Avatar
Another grey water question.
Our old 1997 Jayco popup and a friend's 2009 Coleman popup had a waste "garden" hose connection from the sink. We used to just used roll out a the garden hose from the popup and drain to the ground. This would be the same as tent campers who wash their dishes in a bucket and tip it out on the ground.
My question is if you are only using your kitchen sink is it ok to drain your grey water to ground??
Oh and what about the outdoor shower.
Barney
2012 Rockwood Roo 233s
2011 Ram 1500 Big Horn V8 Hemi
Previous Trailer -> 1996 Jayco 1207
Barney1 is offline   Reply With Quote
Old 05-31-2012, 02:29 PM   #4
I would say not to drain gray water on the ground due to chemicals in it. A safe option is taking to bath house and flushing or pouring into pit toilets. I adapted a garden hose to hook to drain and empty into a 5 gallon blue water jug.
Old 05-31-2012, 02:37 PM   #5
Gray water discussions around here can get pretty heated. Depends on the state and local laws on whether you can just let it run on the ground. If not, one of those portable totes can be used to collect the water and transport to the dump station.
Len & Cheri is offline   Reply With Quote
Old 05-31-2012, 02:42 PM   #6
If you leave a hose connected to the sewer and connected to your pop up drain, you may get some sewer gas smell from the sink. I assume you don't have a holding tank.
If I'm conencted to a sewer on site with my TT, I never leave the dump valves open. Let the tanks fill up, then dump. This prevents sewer smells from entering and allows for proper dumping/clearing out of the sediment & solid waste in the tanks.
You could collect grey water in a tote or bucket, and dump it down the sewer as needed.
SCOC is offline   Reply With Quote
Old 05-31-2012, 02:57 PM   #7
Barney1's Avatar
It seems that a lot of people here in Ontario with popups and no holding tanks drain their sinks to ground. I'm our new Roo 233s I am not sure what to do. We haven't used the black water tank yet and there are no chemicals in the grey water tank other than soap.
Totes are $$$$$$
Barney
Old 05-31-2012, 03:07 PM   #8
To be on the safe side, I would dispose of it at the dumpsite or down the sewer hook up
Old 05-31-2012, 03:46 PM   #9
papap's Avatar
Top stop the smell from coming up hose from sewer. Just make an P trap in hose. this is not hard to do. Just raise hose at a couple of stops. This will let water stay in low spot.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 06-02-2012, 12:27 AM   #10
1l243's Avatar
If you got food particles in your gray water it could attract critters if you just dump it on the ground. In bear country that could be a problem not only for you but the guy that comes after you...
You can dump into the sewer but you will need a P trap like said above and you could use something like this.
Google Image Result for http://images.campingworld.com/is/image/CWI/multiimages/36542n.jpg%3Fop_sharpen%3D1%26layer%3D1%26src%3DCW I/logo.gif%26sizeN%3D0.3,0.3%26posN%3D.32,.3%26opac% 3D20
1l243 is offline   Reply With Quote
