Old 07-19-2015, 04:26 PM   #1
wlhpas's Avatar
Send a message via AIM to wlhpas
grease buddy bearing
I have a Crusader 290RLT and want to know how often and how many pumps of a grease gun to the " Buddy bearing" ( wheel bearing )?
Days camped 2012 - 73; 2013 - 58; 2014 - 41
Days camped 2015 - 17
Bill and Pamela Hancy
TV: 2015 Ford F-250
RV: 2013 Crusader 290RLT
wlhpas is offline   Reply With Quote
Old 07-19-2015, 05:14 PM   #2
I grease my bearing buddies once at the beginning of the season. I jack up one side enough for both tires to just clear the ground? Remove the rubber caps and scrape out as much old grease as possible from the bearing cover. Then put enough grease in so that it flows from the bearing, while spinning the tire. Spinning the tire distributes the new grease throughout the bearing.
2013 Rockwood Signature UltraLite 8319SS
propbndr is offline   Reply With Quote
Old 07-20-2015, 08:06 AM   #3
wlhpas's Avatar
Thanks for suggestion. Sounds like that will be the best way to go and only once a season.
Old 07-20-2015, 04:20 PM   #4
Brother Les's Avatar
With the tire that you are greasing up in the air, grab the tire and pull it in and out to make sure the bearings are not loose. You may have to tighten them up at the castle nut. Your axle manual will tell you to remove the hub and and check and hand grease/pack the bearings once a year or any warranty will be voided.
Brother Les
Old 07-20-2015, 04:29 PM   #5
I do hope you folks are referring to the axles with the zerk in the end and not a true Bearing Buddy which is a definite NO-NO on a hub with brakes.
Old 07-20-2015, 04:29 PM   #6
+1 on the rocking the tires to check for loose bearings, I forgot to add that step to my post. Just a warning on this step though. Only grab the tire on the side. DO NOT put your hand under the tire. If the jack slips while your hand is under the tire....I'll leave your mind to imagine what will happen to your hand.
