Old 04-07-2014, 09:07 PM   #1
goofey chuck's Avatar
Great first trip to Florida! Tracer 3200bht But?
Great first trip to Florida! Tracer 3200bht we have 1 outlet on the kitchen slide out not working though.... Any thoughts?
goofey chuck is offline   Reply With Quote
Old 04-08-2014, 08:31 AM   #2
Is it a GFCI protected outlet? If it is, then check and reset the GFCI. It's common, for one GFCI outlet, to control several, usually in the kitchen or bath areas.
Is there a breaker tripped? If so reset the breaker and try again.
*If it's new, then the dealer should handle it under warranty.*
If it's used, then turn the power off, remove the cover, unscrew the screws holding the plug in the box , and make sure all the wires are connected.
If that looks fine, then flip the power on(do I need to include a cautionary comment here?). Using a Tic Tester check to see if there is power on the wires where they connect to the outlet backside.
The tic tester will make a tone or beeping, if there is power there. Usually the beeping will be from contact with the black wire, but check all of them. If there is power there, but the the plug still isn't working, then replace the plugin. If not, then you have to trace the wires back to the next connection, be it at the breaker panel, or, if this plug is on the same circuit as one or two others, find the one it draws power from(think of up stream and downstream here, and check the next closest outlet in the kitchen to this one). Simply trace things back, until you find the problem.
Good luck.
katkt is offline   Reply With Quote
Old 04-08-2014, 09:04 AM   #3
AquaMan's Avatar
If it's only one outlet, it's most likely not a GFCI problem. The GFCI outlet(s) control all the outlets in a trailer, depending on size, you may only have one outlet that controls all of them. This also includes the refrigerator in most units. Also, the outlet may be of the type that doesn't have any screws holding it in place, but rather clips into the box itself. If all other outlets work and the wires on that outlet are connected correctly and securely, check the outlet to either side for a continuing run to your non-working outlet.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
