Old 06-16-2015, 07:51 AM   #1
Grey water not draining!
I have a brand new Salem light tt. 2015. First road trip. Grey water tank won't drain. Do I need to find RV place to get fixed? Or simple solutions.
wildtigger2 is offline   Reply With Quote
Old 06-16-2015, 07:55 AM   #2
Might be a (Floating Disk) leads that way since it is (Brand New). The repair will be (More Pleasant) than if it were the Black tank! Youroo!!
youroo is online now   Reply With Quote
Old 06-16-2015, 08:04 AM   #3
Boss Ox & Drovergirl
oxcamper's Avatar
Sounds like a valve problem. Do you get any resistance when you pull the grey tank valve?
Mark, Vicki, & Scout THE dog
2015 Hemisphere 282RK
2010 F250 Super Duty
1992 Goldwing Aspencade
oxcamper is offline   Reply With Quote
Old 06-16-2015, 08:39 AM   #4
No resistance. Trying to find a repair place on the way to Casper wy right now. Murphy's law it would go out while on first trip and not during its testing trip
Old 06-16-2015, 08:44 AM   #5
Dumb question, are you sure there is anything in the tank? Could be the valve was partially open and it drained on it's own.
Old 06-16-2015, 08:53 AM   #6
Yes water in tub backed up
Old 06-16-2015, 08:57 AM   #7
PhoneDude 8289's Avatar
Check valve stem, maybe it came unscrewed out of the valve. Should be a little resistance pulling the gate open.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is offline   Reply With Quote
Old 06-16-2015, 11:30 AM   #8
This may sound stupid but out trailer had two gray tanks. They only showed us one. The other one is tucked behind the wheel well with a separate lever.
clavigne67 is offline   Reply With Quote
Old 06-16-2015, 04:53 PM   #9
This may not be helpful, but I had a Thor Hurricane that had a valve on the opposite side from the dump valves. This valve emptied the grey tank to the other side of the RV. If we didn't open this valve, nothing happened on the other side when grey water valve was opened.
Maggiewaggie is offline   Reply With Quote
Old 06-16-2015, 06:36 PM   #10
The operator cable probably pulled out of the valve. It is held in place with a set screw. May have to open up a belly pan to get to it. May have to replace cable
Harkerr is offline   Reply With Quote
drain, grey water, water
