Old 12-27-2015, 05:11 PM   #11
I thought the camera only works in reverse? If so then the TV needs to be in reverse with the lights on for it to work.
Mahlstedtd is offline   Reply With Quote
Old 12-27-2015, 05:53 PM   #12
Usually Confused Member
emm-dee's Avatar
Originally Posted by PenJoe View Post
Okay, I have the wired/remote concept- a simple 12V circuit and no video feed in the Furrion line When you were checking and got no power reading, did you have a complete circuit? You may have 12V to the camera fitting, but unless it has a ground, you will not get a reading-the circuit is not complete.
Also, how did you remove the Furrion plug to replace it with Tadi Brothers? Is it possible that the power (running lights) was on and shorted out in the exchange process? It may be that the running lights, though on the same circuit as the camera, route through a fuse before going to the camera terminal. If the camera shorted out, the running lights would remain on. A camera fuse is very low amperage. If that is so, you may want to check the fuse panel.
None of us being there, hopefully one of our guesses solves your problem.
Nice catch. When cutting the Furrion connector off and having it powered should kill a fuse but it would be the running light fuse. At least on my unit (Vengeance..very similar to the Grey Wolf) there is not a separate camera fuse. That "apparently" single line actually contains two pretty small gauge wires...positive and negative so a wire cutter will definitely short the system.
The connection for the Furrion is powered any time the running lights are on. It's designed and advertised to be an "observation camera", not a backup cam. The observation cameras, when working properly, are a great feature while driving. You can see things behind you that you'll never see in a mirror...even those ugly extended side mirrors.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 12-27-2015, 06:57 PM   #13
mdstudey's Avatar
Let us know how you get it to work. I just checked prices and I think this is the route I would like to take.
Chuck & Denise + Pata a.k.a the cg Gladys Karvitz
He is a Master Naturalist She is a quilter and RV Guru
2
008 Dodge Ram 2500 TX Edition2015 - 7 nights, 2 trips, 2016 - 2 trip, 24 nights, 2017 1 trip, 3 nights2018 The great adventure planned and will be rolling soon.
mdstudey is offline   Reply With Quote
Old 01-02-2016, 03:32 PM   #14
Thanks everyone. I puchased a multimeter and checked the lines, there was power with running lights on.The only other small issue I has was that there was two wire green and white, I assumed the green was ground and this was not the case. All is now installed and working correctly. Thanks again Henry
HenryEakin is offline   Reply With Quote
Old 01-03-2016, 02:05 PM   #15
Success
Thanks all for your input. All is working great now. I bought a multimeter and determined that there was power when running lights were on. The only other small issue I had was based on my assumption that a green wire was the ground but I'm my case it was power. Once again thanks.
grey wolf
