Old 09-26-2014, 09:25 AM   #1
1surveyor's Avatar
grill conversion
i have gas line at the back of my FR Surveyor that i want to put a quick connect on for my coleman Q grill , can i do that ? guy at the camper service said i can't use that grill because it is hi pressure and line out of rv is low pressure . why put it back there if it can't be used
thanks Oak
1 Surveyor
2015 Silverado Duramax w/Allison transmission
2014 surveyor 293RL fifth wheel
1surveyor is offline   Reply With Quote
Old 09-26-2014, 09:33 AM   #2
wmtire's Avatar
thanks Oak
The low pressure line is made for grills like the Sidekick, Olympian, and such.
http://www.amazon.com/gp/product/B00...TJQFXNVTR9AE39
http://www.amazon.com/Fleming-Sales-...sidekick+grill
You can actually do mods to either your Coleman or tie into your RV tanks BEFORE they go thru a regulator (thus lowering the pressure)....and use your Coleman. If your Coleman has the regulator built into the flame control, this can be a problematic endeavor. If the regulator is separate, then you can modify it, by basically removing the grills regulator.
The problem (and there are many, many, threads on these forums about this), is you are trying to use Your Coleman grill (which has it's own hi pressure to low pressure regulator built in) on a line that has already been regulated down from hi pressure to low pressure.
You are then actually trying to run the grill off of propane that has been regulated down twice....which is too low to successfully run the grill on.
The low pressure grills don't have a built in regulator, thus they are made to operate off of the RV's already regulated low pressure propane lines.
Hope this helps.
2011 Flagstaff 831 RLBSS
Old 09-26-2014, 11:28 AM   #3
1surveyor's Avatar
Thanks for the info I'll try and see if I can do the conversion to my grill before buying a new one
1 Surveyor
Old 09-29-2014, 01:27 PM   #4
nbenn3's Avatar
Name:	ImageUploadedByForest River Forums1412015248.244008.jpg
This is what I did to mine and it works perfectly. Actually got this from another thread on here.
nbenn3 is offline   Reply With Quote
Old 09-29-2014, 05:34 PM   #5
deartruc's Avatar
Your Coleman grill should be low pressure. I'm not sure of a grill manufacturer that makes a high pressure grill. When my Olympian burned out after two years (and I opted for the stainless steel one figuring it would last) I bought a Coleman freestanding tailgate grill and its worked fine ever since.
2017 GMC Yukon
2018 Roo 23 ikss
deartruc is offline   Reply With Quote
