Old 04-18-2016, 10:04 AM   #1
Gross weight vrs dry weight
The specs on my trailer has a gross weight 7,505 is that the max the trailer will take? And the dry weight 4,549. The weight of the frailer alone?Click image for larger version
Stetay is offline   Reply With Quote
Old 04-18-2016, 10:14 AM   #2
BigDaddy1967's Avatar
The 7500 number is likely the GVWR, but usually dealers have pictures that show the GVWR and GAWR for the axles. The capacity listed was an arbitrary number. What matters to me is properly distributed load, and that when you cross the scales you do not exceed any of a weight ratings for the TV and the trailer.
2014 Ford F250 Super Duty, 6.7L Diesel, Ultimate Lariet package
2016 Forest River, Heritage Glen 272RL
BigDaddy1967 is offline   Reply With Quote
Old 04-18-2016, 10:24 AM   #3
fonzie's Avatar
The dry weight is the trailer weight when empty = 4549 lbs
The cargo weight is what you can put in the trailer = 2956 lbs, that includes propane, clothes, food, dishes, battery etc etc
The gross weight is the empty trailer + the cargo weight = 7505 lbs, that is the maximum the trailer can weight when pulling on highway......
Fonzie
Old 04-18-2016, 10:44 AM   #4
Fulltime family RVer
Yup. Remember, the pulling on the highway part has to include everything you put into it including water.
Old 04-18-2016, 11:58 AM   #5
Airdale's Avatar
On the LH forward external section of your trailer you will find a tire placard and federal certification label. It has the official information such as GVWR, GAWR, rim & tires size (s) and the recommended tire inflation pressures. See the reference below.
The document you provided in your post is not official but nice to know. Some of the information could have changed if options were installed by a dealer.
http://www.irv2.com/photopost/showfull.php?photo=27421
A Trailer Tire Poster
http://www.irv2.com/photopost/showfull.php?photo=15339
Airdale is offline   Reply With Quote
Old 04-18-2016, 12:54 PM   #6
Also try to find out what is included as your dry weight. I have found out that each manufacturer is different. Apparently one very large company didn't include the cabinets in their dry weight for a number of years.
Always best not to push your Gross Weight and make sure you keep it well under your truck's Gross towing capacity. Remember that weight includes you, your family, and the dog.....
Dan
2005 Chevy Tahoe
2014 Surveyor Select SV 264
2017 - 45 Nights Camping
Beluga is offline   Reply With Quote
weight
