01-17-2020, 08:02 PM
Hanging stuff on camper walls
Wondering how people hang stuff securely to the walls of their campers. We’d like to start personalizing with some picture frames and such but want it to be solid. We do travel with our unit. All feedback appreciated.
01-17-2020, 08:16 PM
The interior walls in my camper are very thin panels - 1/8 inch thick. For something like a towel ring that can’t be screwed into backing, I use a short hollow wall expansion anchor, commonly called a molly. These are quite permanent, and if you can’t access the backside, you can’t remove them without cutting the outer flange off and pushing the anchor into the wall. If you have access to the backside of the panel, like from inside a cabinet, you could add some backing behind the screw fastener. For lightweight items I can get by with a sheet metal screw, but then I attach Velcro to the bottom corners of the item to keep it from swinging. “Studs” are generally 1x2s, so don’t expect much strength there.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
01-17-2020, 08:22 PM
Command strips work well. ....................
But I am lucky the DW hangs no pictures and does little to no decorating.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
01-17-2020, 10:59 PM
Command strips...
They make some for picture hanging and some for use outdoors.
I like the outdoor kind because it holds up to our humidity. I just cut off the tabs to make them like the picture hanger ones when hanging pictures. Make certain you clean the wall with alcohol first and let them alone for 24 hours before putting up the pictures Buy ones that are rated higher than the weight you want to hang.
We've traveled thousands of miles with them hanging stuff on the walls and they still hold.
2015 Dynamax REV 24TB class C
01-18-2020, 03:10 AM
Always Learning
We don’t have a room we haven’t made changes to.
Command Hooks, screws, screws + anchors, Velcro, backer board (held on with screws). All the things!
Just depends on what you’re hanging, what studs are available, and where you’re hanging it.
01-18-2020, 11:21 AM
Gold Tee Box
Check out 3M Scotch Extreme. I keep a roll of it in my camper supplies. It will work well on wall hangings, or to keep things from slipping around on tables.
Success is hiring someone to mow your lawn so you can play golf for exercise.
2018 GMC 2500 Duramax Denali
2018 Coachman Freedom Express 287BHDS
01-18-2020, 11:55 AM
^^^^^YES^^^^^^
2019 Hemisphere 272RL
2015 Ford F250 6.2L
2005 Jayco Bantam Flier
Hensley Hitch
01-18-2020, 01:13 PM
Command strips
Bob & Laurie w/Missy
Sayre, PA
2016 Flagstaff Micro-Lite 21 DS
2015 Ford Explorer
Command strips, Command hooks, wall anchors. It depends on what We want to hang and if it will be removed at some point. Wife hung metal signs with the Velcro style Command strips and they have stayed in place for years.
John And Mary
2016 Venom 3311TQ
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (27) 2017 (32) 2018 (34) 2019 (35) 2020 (20) 2021 (5)
01-18-2020, 01:29 PM
Old Engineer
3M's Command Strips, Velcro, and screws where appropriate.
All work well depending on what is being mounted.
For adhesives, clean both surfaces well with alcohol first.
If drilling a pilot hole for a screw, use a drill stop to prevent hitting wires or drilling to deep.
An electronic stud finder can help locate wood or metal structures in the wall to mount to.
2019 Dynamax Isata 3 24RW
Smart Car Towed 4 Down
Quote: "When all else fails, read the manual!"
01-18-2020, 02:19 PM
We purchased our 5th wheel used. the previous owners added some very nice shades to the windows, but left numerous holes from their trying to find good mounts. Any suggestions on filling the holes??
01-18-2020, 02:47 PM
Command strips, also photo shops will print photos on aluminum. We have our kids and grandchildren’s photos Command striped directly to our walls.
01-18-2020, 05:18 PM
Always Learning
Ohh, I also missed “Very High Bond” tape!
01-18-2020, 06:40 PM
Chris and Cecil
Painters putty. It’s paintable.
2022 Grand Design 295 RL fifth wheel with Anderson hitch
2018 Dodge Ram 2500 Heavy Duty diesel
01-18-2020, 07:06 PM
That stuff is great! Being in in a hot climate, I use adhesive promoter before installing and it stick at 110+. Including my brake controller.
Just glad to get away
01-19-2020, 08:19 AM
Used to use double sided tape, now command strips. Most times I use the ones with Velcro built in
01-19-2020, 08:24 AM
Command strips for pictures, over the door towel and clothes hooks, toggle bolts for paper towell holder, and screw for leash holders on outside wall by door.
2019 Cherokee Grey Wolf 29TE
2018 Ford 150 SCAB STX 3.5 EB
01-19-2020, 03:14 PM
Will echo recommendations for Command products.
The ability to take down and securely stow items that have frames with protective glass is one good reason.
We typically travel 11 miles into a lakeside site on a very rough, washboarded, potholed gravel road. Screws fall out of places like losing fillings in teeth. Given the tissue paper thickness of interior panels, screwing things to walls is just asking for trouble unless you can restrict yourself to studs or aluminum framing. But command products attach nicely to paneling...and the backs of frames. Before rolling out, take down the decorations and store them safely. Put them up on site.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
01-19-2020, 06:21 PM
Has anyone tried the stickup picture tiles? Any idea how well they work in an RV as far as staying on the walls?
Eric
2019 RAM 3500 Laramie DRW
2020 Wolf Pack 325pack13
