Old 05-27-2016, 07:04 AM   #1
KDHfan's Avatar
Hard Start Cap?
I'm camping this weekend and will be bringing along two Honda i2000 inverter generators with a parallel cable. I have a 13,5 a/c unit... Do I need to install a hard start capacitor before running the a/c unit? This camping trip is a 1-time thing (not having access to 30amp), so I don't want to go through the hassle if I don't absolutely need it.
I have access to 15amp power, but the run is about 150', so I didn't want to try and run the A/c using standard power cords. Was figuring the two honda's would be better?
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 05-27-2016, 07:49 AM   #2
Usually Confused Member
emm-dee's Avatar
I have the same setup and it works just fine. My hard start capacitor is sitting in a cabinet until I find the wires to hook it up to.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 05-27-2016, 07:50 AM   #3
You should be ok with the two Hondas and no hard start. I run two Yamahas with our 15k unit and it works great. I did add a hard start last year but went the first year without one. I find the two Yamahas to be quieter and use less fuel than the onboard Onan 4K unit.
You might find it better to switch off the eco mode when starting up the AC unit.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 05-27-2016, 10:14 AM   #4
Sc00ter's Avatar
Devils advocate... A hard start cap is rather cheap and easy to install. I wasn't going to put one on our rig until I found the one I bought for our last camper. Installed it just because we had it and the ac seems to start faster. Not a very scientific answer I know but for the few $$ and it reduces the load on the gen sets then to me it would be worth it to me in the long run.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 05-27-2016, 10:22 AM   #5
Pickin' & Campin'
You should be just fine for this weekend without the hard start cap.
If you are short on time, don't sweat it.
I do agree though if/when you have an opportunity, install the cap.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 05-27-2016, 04:31 PM   #6
KDHfan's Avatar
Thanks for the responses. Just going to roll with it this time. Hope everyone has a safe and happy holiday.
