Old 08-25-2010, 07:52 AM   #1
skeeterbait8's Avatar
Wink Have you ever crawled up under your rig?
Have you ever crawled up under your rig to just look to check things out? I finally did a couple days ago. I've been meaning to for a long time, finally did it. What amazes me is to see so few braces that actually touch the flooring! I guess that is part of how they keep the weight down.
Good news, everything looks perfect under there. NO holes, no signs of rot or anything.
Official member of the "Roo Kroo"!
2009 - 4, 2010 - 135
2011 - 95 and counting
skeeterbait8 is offline   Reply With Quote
Old 08-25-2010, 08:37 AM   #2
Yes, I've crawled all around under ours. It's a sealed underbelly so there's not a lot to see but I check to be sure it's not torn and that the foam sealant is still in place, etc.
Gotta go campin!
Old 08-25-2010, 11:53 AM   #3
milzat's Avatar
Yep, been under mine a few times. I completely removed the under-belly material to check things out. I re-routed a few wires and heating ducts; and the fresh water drain tube. Also, I sealed a few holes with expanding spray-foam.
If you have an enclosed under-belly, you would be surprised at what you'll find hiding back there. A cap at the heater plenum had fallen off and allowed most of the heat to escape into the under-belly; instead of to the ducting.
milzat is offline   Reply With Quote
Old 08-25-2010, 02:35 PM   #4
doctort44's Avatar
I crawled under mine for the first time about a month ago and found a 6" piece of rebar stuck into the underbelly. About 3" was stuck in and the other 3" sticking out. I removed it and covered the hole with Gorilla Tape. Good as new! But now, I check under there almost every time we take it out.
Terry and Joan and our empty nest
2008 Silverado Crew Cab 5.3liter 3.73
"The Cottage" (2010 Surveyor Sport 189)
doctort44 is offline   Reply With Quote
Old 08-25-2010, 03:32 PM   #5
fivecodys's Avatar
Yep!
Did it a month ago to adjust the brakes.
Good thing I did too.
My tires had radial cracks on the sidewall running all the way around the rim.
They looked great on the outside.
I was heading for disaster.
Will do this more often now.
Bill
2009 Flagstaff 8528 RKSS
2019 GMC 2500 HD Diesel
Pullrite Superglide 14K
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 08-25-2010, 08:35 PM   #6
Villa Estate 392FLFB
The_Stuff's Avatar
i looked under mine today to. ground cable broken off under and some hoses (hot and cold) that come under and go to nowhere...
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 08-25-2010, 09:16 PM   #7
Mr. Black's Avatar
Almost everytime we go somewhere I go under the trailer for a look see. Mostly checking the suspension for broken springs or bad brake wires.
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
Old 08-25-2010, 10:08 PM   #8
NWJeeper's Avatar
I have been under, over and through just about anywhere I can squeeze into in order to run wiring for the inverter, solar panels, satellite, installing batteries, air horns, you name it. I like to know where things are and how things are put together in case I need to fix something in the future.
Ed & Wendy
www.nwjeepn.com
Old 08-27-2010, 10:47 AM   #9
The_Stuff's Avatar
I mostly went under to see where my tanks are and look for a spare.. it appears my trailer doesn't come with one..
