Old 07-19-2011, 02:31 PM   #1
ladywendolyn's Avatar
Have you had this air conditioning mystery?
I woke up today and had my daughter turn on our rooftop air conditioner (non ducted) We are staying somewhere that it is very hot all day, but cools down at night. I got out of bed 20 minutes later, and noticed it was awfully quiet. It seemed that the compressor was working, but the fan was barely pushing any air out. Boy was I mad, a brand new unit, and now no fan. After calling around... No service available for a week... I pulled the grill off and looked inside. I noticed a bit of ice inside, so I turned it off to let it melt, and also put a little fan inside to help with it. One hour later... Ice is gone unit is working fine.....
But here is the question.... It was off all night...how could it be iced up so soon? Could this still be ice from yesterday? My daughter turned it on... If she accidentally turned it to the heat option... Would this cause icing? Anyone else had this experience? I am keeping the little fan running inside the unit, to help it not ice up... Anything else I can do?
Lady Wendolyn
2003 21 ft Forrest River Shamrock
Manitoba Canada
ladywendolyn is offline   Reply With Quote
Old 07-19-2011, 02:48 PM   #2
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
No mystery. Phenom is called icing or freezing. Lots of info out there. Try searching for "rv air conditioning icing." Keep the fan on "run."
dimurrrw is offline   Reply With Quote
Old 07-19-2011, 03:36 PM   #3
This can be caused by dirty filters or dirty coils, also running the unit on "ON" instead of "AUTO" will cause this, because the compressor coils need time in the off mode to thaw out before coming back on to cool again. Which is also why running it on "LOW" isn't a good idea either. Not enough thawing out time. Our Coleman popup had some of these problems, which are also closely related to trying to cool a tent, basically. Also, humidity plays a role in the equasion, as well. We live in humid Florida. You cannot expect much more than a 20 degree drop in temperature inside the camper from the outside temp, so if it is 95 outside, 75 will be about it inside. Randy
Old 07-20-2011, 06:25 PM   #4
Villa Estate 392FLFB
The_Stuff's Avatar
you sure the AC's fan is going? if it stopped it would ice up.
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 07-21-2011, 08:44 AM   #5
jimh's Avatar
i wouldn't think switching from heat to cool would cause that. although, there are a different set of problems that occur with the switch valve inside a heat pump. (that's all i've ever been told...they didn't go into detail).
the air flow would be from the ice. u could have shut it down and waited abt 5 minutes and switched to heat for a couple (2) minutes and it would have thawed it out.
if it gets the trailer down to temp and then does it i would have it looked at. it could be humidity.
when i bought my trailer, on the walk thru, they told me that if i opened the quick cool vent on the a/c for a long time, it would ice up. (mine is ducted). quick cool would make it work more like a non ducted unit.
jimh is offline   Reply With Quote
Old 07-21-2011, 09:20 AM   #6
trudinator's Avatar
Our house A/C isn't working properly, so we slept in our Rockwood TT for the last 2 nights. It was 99 yesterday during the day, and only "cooled" down to 88 by the time we went to bed. Humidity has been so thick you could cut it with a knife!! I'll be SO glad when this "heat dome" moves on. We're in Wisconsin, and I'm not used to this many days in a row with staggering heat and humidity. Our 13,000 BTU A/C has had no issues keeping up, although we're running it only at night. I'm pretty sure our AC is much more than a 20 degree drop in temp from inside to outside.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 07-21-2011, 09:29 AM   #7
PINTO
Kpinto's Avatar
On your A/C that is freezing up. If the thermostat wire, cooper wire with a bigger end on it has came loose and dropped down off of the condenser it will cause it to freeze up because it will constanly run. Something is making the compressor run all the time and there has been a few reasons why listed. The only other thing would be if the unit is low on freon, probably not likely but possible.
PINTO
2011 Flagstaff 8528 TBWS
2008 Duramax Diesel
Chevy 3500 LTZ Dually
Kpinto is offline   Reply With Quote
Old 07-21-2011, 09:50 AM   #8
Bill_C's Avatar
I wish it would get warm enough here in BC to turn off the HEAT !!
DRINK COFFEE--do stupid things faster and with more energy ! Rockwood 5th wheel, Signature Untralite, 8244S
Tow Vehicle: Ram 3500 6.4 litre Hemi.
Bill_C is offline   Reply With Quote
Old 07-21-2011, 10:55 AM   #9
The_Stuff's Avatar
the heat wave lifted here last night about 9pm! AC cut out and gf and i were like 'whats wrong with the ac' then we noticed it was down to 21 in the TT!
(70f)
Old 07-21-2011, 12:58 PM   #10
trudinator's Avatar
(70f)
Please, please PLEASE send that our way!! We have to wait until Sunday night before nighttime temps are back down in the 60's. Can't WAIT. Please remind me I'm saying this in January/February if I start complaining about the bitter cold.
air conditioner
