Old 09-30-2012, 08:46 AM   #1
Head lights not working
We went to leave last night and had no headlights! I checked every fuse I could find and all was good. Everything else is working including the rest of the lights on the exterior. Any ideas?
Glucas is offline   Reply With Quote
Old 09-30-2012, 09:07 AM   #2
Hello, and to the forums. Hope you enjoy the stay, and learn a lot, and can teach others what you already know.
It would help a lot to now what we are talking about. Motor home, one can only assume. How about year, make, model. And might want to post in that section instead of general repair. Just hang in there, you'll get some answers. Don't forget the fuse.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 09-30-2012, 09:25 AM   #3
Headlight Issue
Sorry, it is a 2009 Georgetown 35' SE with a V-10 Ford Chassis. I have inspected the ground on the upright and all seems ok. I have checked all the fuses and all are good. High beam indicator is on with no headlights or fog lights - all other exterior lights are working.
Old 09-30-2012, 09:53 AM   #4
I am not sure what happened but all the lights are working except the drivers amber light. Switched bulbs and still not working on drivers side.
Old 09-30-2012, 10:31 AM   #5
VinceU's Avatar
Sounds like problem A was account of intermittent headlamp switch or relay.
Orange light socket corroded or single element bulb as to dual element. Socket will receive either. Dual elment if signal and marker
