Old 09-23-2010, 05:43 PM   #11
Just like NWJeeper I have used compressed air to blow out the water lines. I do put a small amount of the antifreeze in the P-traps just in case. It gets quite cold here in eastern Ontario. I have never had a problem and I do not put any heat in the unit. The pex pipes in any event have significantly fewer problems with freezing than copper.
Mike
MikeA is offline   Reply With Quote
