Old 10-03-2012, 12:50 PM   #1
hkreck's Avatar
heating during storage?
I was wondering what might be the best way to provide some heating to my motor home while I store it for the winter? I have it parked on a pad next to my garage with a cover on it and I have it winterized. But I've gone into it a couple of times and found it pretty cold inside. I know a lot of people keep their RV plug in during storage and I was wondering if anyone puts a small electric heater in to warm things up a little? Or what might I do about this?
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 10-03-2012, 12:57 PM   #2
Capsfloyd's Avatar
Plug it in and buy one or two of the oil filled. Heaters to place in side
This is just to spread some heat in your MH
You have it winterized through out ?
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
Old 10-03-2012, 12:59 PM   #3
Dave_Monica's Avatar
Sounds like it's covered, meaning all slides are in...what would be the purpose of heating it?
Our camper sits in the driveway all year plugged in, no heat. I've plugged in a ceramic heater to warm it up if I'm doing work in it in the early spring.
Dave
Old 10-03-2012, 01:27 PM   #4
trudinator's Avatar
Dave
x2. We don't heat ours during the winter unless we're working on a mod, fix, etc.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 10-03-2012, 01:31 PM   #5
Camper Less Camping
Cajun Po-Boy's Avatar
Don't see any need to heat, winterize, cover and forget about it
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 10-03-2012, 01:38 PM   #6
TURBS's Avatar
I don't see any reason to heat your mh.
Turbs
Old 10-03-2012, 01:42 PM   #7
MtnGuy's Avatar
When the temperatures get down into the lower teens or lower, I will either the furnace of a small electric heater so the vinyl floor doesn't crack.....I have read that that can be a problem sometimes.
Old 10-03-2012, 02:22 PM   #8
CLASS "A" Senior Member
cfsoistman's Avatar
If I haven't winterized yet and a coldspell comes in I use 2 electric heaters set on 600 watts. I plug one into the standard receptacle circuit up front and the other into the GFIC circuit in the rear bathroom with the door open. That way I can turn them up to 1500 watts if I go out to watch football and not trip a breaker. I also leave the cabinet doors open so the heat gets to the water lines. I'll turn on the Artic Pack as well. So far in 6 years I've done this twice.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
cfsoistman is online now   Reply With Quote
Old 10-03-2012, 07:18 PM   #9
hkreck's Avatar
Sounds like I don't need to worry about it, I have been told to run the generator once in a while to reduce problems with it. I figure on running the diesel engine at lease once a week after the real cold weather starts. any other suggestions? or ideas?
Henry & Tena
2013 Solera 24S
The Great Escape
Old 10-10-2012, 09:39 PM   #10
cmcct's Avatar
I use a small (750 watt) oil filled heater. I set it on low, just enough to keep it from going to freezing temps inside the trailer. what that does is it sets up convection currents in the trailer to move the air so the dessicant traps can do a better job of keeping things dry inside. Kind of important living here in Vancouver.
Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd.Driver:Clint, Navigator:Melanie, 1 dog (Great Pyrenees/Akbash cross) and now a cat too. Mission Statement: Just another adventure! Towed vehicle:2009 Roo 19 with lots of mods!
cmcct is offline   Reply With Quote
