Old 10-27-2011, 02:24 PM   #1
dretired's Avatar
heating inside of fifth wheel while traveling ?
Can it be done ?? If its cold after Christmas, when we head toward Florida, (from Michigan )can we somehow heat up the inside of the 5th wheel an hour or 2 before we stop for the evening ??
dretired is offline   Reply With Quote
Old 10-27-2011, 02:27 PM   #2
TURBS's Avatar
I believe you need 110 volt to be able to do that unless you have an invertor
Old 10-27-2011, 02:47 PM   #3
MtnGuy's Avatar
Hmmm.....I would think that it could be done by just running your furnace. I don't think the wind would blow out the flame, but maybe others can answer that have tried that. The TV power would help keep the camper battery charged.
Old 10-27-2011, 04:42 PM   #4
dretired's Avatar
Thats the question then... Can you run the propane furnace while going down the highway ??
Old 10-27-2011, 05:01 PM   #5
You can run a propane fridge while driving. Ours HAS to have electricity from something though to start. It won't start or continue to run without a charge on the battery (don't ask how I found out). I don't know if the furnace would need a "spark" from a battery/power cord or not.
Karen
Enjoying the great outdoors with one hubby and 2 boxers!
2011 Georgetown 280DS
2010 Jeep Wangler 4x4 Toad
KarenS144 is offline   Reply With Quote
Old 10-27-2011, 05:12 PM   #6
Hoo Dad's Avatar
If your fifth wheel is nearby....hook up, turn on the furnace and see if it works. I run my fridge all the time but I don't know about the furnace fan whether or not it will operate. I'm sure there are plenty of others out here that know. However, try hooking up. Let us know if it works as some of us will be heading to Florida also.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 10-27-2011, 05:24 PM   #7
TURBS's Avatar
ok I just tried mine and I was wrong my furnace kicked on while only on 12 volt and no shore power !
Old 10-27-2011, 05:31 PM   #8
dretired's Avatar
...Its in the driveway.. i will try and see if the furnace runs with out being hooked up to shore power.. it should... it would be nice to pull into a rest area about an hour or 2 before we get to the campgrounds and pre heat the 5th wheel a little
Old 10-27-2011, 05:32 PM   #9
3 Happy Campers's Avatar
Yes you can run the furnace in a 5er while driving down the road or while not plugged in. If you couldn’t, boondocking in cooler/windy weather would not be possible.
We travel from PA to FL the last two weeks of Dec almost every yr.
We have a programmable thermostat.
We leave on Fri just after rush hour.
I have the thermostat programed to kick on about midnight.
I’m usually ready to pull over about 2am.
If you don’t have a programmable one you could just turn it on during your last pitstop before you know you’ll be stopping for the night.
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 10-27-2011, 05:39 PM   #10
wfmdfm's Avatar
yes
Yes it can be done and I have several times. As recently as last week. On the last stop prior to the campground I turn on the heat and the hot water. As soon as you put out the slides it cools down but still better than sub zero. I am sure that I will be criticized by some for doing it but it has worked fine for our last 2 trailers.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
Old 10-27-2011, 05:41 PM   #11
dretired's Avatar
Smile
Thank you !!
Old 10-27-2011, 08:54 PM   #12
sherdep's Avatar
one thing to remember is you will need a good charge on the battery and propane in the tanks - without those two ya cant.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 10-28-2011, 08:37 AM   #13
Rugged Brown's Avatar
My only concern is that a couple of the heating ducts are covered when the slide is in, therefore I would gain nothing, unless I travel with the slides open.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 10-28-2011, 08:59 AM   #14
There would be no negative effect on the system if a couple vents were covered. Air would just flow to those vents that are not covered probably the bedroom & bathroom (most important when traveling in the winter!)
In my Sierra 356RL all ducts run right down the middle of the unit so none are covered.
Perkasie, PA
2010 Sierra 356RL
Old 10-28-2011, 09:00 AM   #15
TURBS's Avatar
Tv will keep battery charged while driving
Old 10-28-2011, 09:06 AM   #16
If you travel during the winter & don't check your tanks regularly you deserve to be cold!
In any TT I’ve ever owned the trailer battery is maintained via the umbilical cord plugged into the tow vehicle.
Perkasie, PA
2010 Sierra 356RL
Old 10-28-2011, 02:32 PM   #17
dretired's Avatar
I will have to check that on mine..
Old 10-28-2011, 07:07 PM   #18
flyrotor's Avatar
Yes it can be done, for years my dad's company hauls flowers (potted plants) in cargo trailers, the heaters they use are specifically from motorhomes with forced air vents, it works great, they will run nearly a week in very cold tempuratures on two 30# tanks, the wind does not blow out the flame. The batteries will hold their charge while plugged into the truck while driving. (Yes it takes a lot to charge the batteries from your tow vehicle, but to maintain them is much easier)
Many vehicles run on propane, you can run the propane while driving except in certain locations such as tunnels, also avoid running the heaters while fueling, just use common sense and you will be fine.
flyrotor is offline   Reply With Quote
