Old 10-27-2011, 02:24 PM   #1
dretired's Avatar
heating inside of fifth wheel while traveling ?
Can it be done ?? If its cold after Christmas, when we head toward Florida, (from Michigan )can we somehow heat up the inside of the 5th wheel an hour or 2 before we stop for the evening ??
dretired is offline   Reply With Quote
Old 10-27-2011, 02:27 PM   #2
TURBS's Avatar
I believe you need 110 volt to be able to do that unless you have an invertor
Old 10-27-2011, 02:47 PM   #3
MtnGuy's Avatar
Hmmm.....I would think that it could be done by just running your furnace. I don't think the wind would blow out the flame, but maybe others can answer that have tried that. The TV power would help keep the camper battery charged.
Old 10-27-2011, 04:42 PM   #4
dretired's Avatar
Thats the question then... Can you run the propane furnace while going down the highway ??
Old 10-27-2011, 05:01 PM   #5
You can run a propane fridge while driving. Ours HAS to have electricity from something though to start. It won't start or continue to run without a charge on the battery (don't ask how I found out). I don't know if the furnace would need a "spark" from a battery/power cord or not.
Karen
Enjoying the great outdoors with one hubby and 2 boxers!
2011 Georgetown 280DS
2010 Jeep Wangler 4x4 Toad
KarenS144 is offline   Reply With Quote
Old 10-27-2011, 05:12 PM   #6
Hoo Dad's Avatar
If your fifth wheel is nearby....hook up, turn on the furnace and see if it works. I run my fridge all the time but I don't know about the furnace fan whether or not it will operate. I'm sure there are plenty of others out here that know. However, try hooking up. Let us know if it works as some of us will be heading to Florida also.
2011 Rockwood 8285 WS
2011 GMC 3500 HD 4X4, 6.0, 4.10, SRW
Hoo Dad is offline   Reply With Quote
Old 10-27-2011, 05:24 PM   #7
TURBS's Avatar
ok I just tried mine and I was wrong my furnace kicked on while only on 12 volt and no shore power !
Old 10-27-2011, 05:31 PM   #8
dretired's Avatar
...Its in the driveway.. i will try and see if the furnace runs with out being hooked up to shore power.. it should... it would be nice to pull into a rest area about an hour or 2 before we get to the campgrounds and pre heat the 5th wheel a little
Old 10-27-2011, 05:32 PM   #9
3 Happy Campers's Avatar
Yes you can run the furnace in a 5er while driving down the road or while not plugged in. If you couldn’t, boondocking in cooler/windy weather would not be possible.
We travel from PA to FL the last two weeks of Dec almost every yr.
We have a programmable thermostat.
We leave on Fri just after rush hour.
I have the thermostat programed to kick on about midnight.
I’m usually ready to pull over about 2am.
If you don’t have a programmable one you could just turn it on during your last pitstop before you know you’ll be stopping for the night.
Dave, Judy & Daisy May
Perkasie, PA
2010 Sierra 356RL
2011 Silverado 2500 4WD, LT, Ext Cab, LB
Duramax 6.6L V8 Turbo Diesel
Allison 1000 6-Speed Automatic Transmission
3 Happy Campers is offline   Reply With Quote
Old 10-27-2011, 05:39 PM   #10
wfmdfm's Avatar
yes
Yes it can be done and I have several times. As recently as last week. On the last stop prior to the campground I turn on the heat and the hot water. As soon as you put out the slides it cools down but still better than sub zero. I am sure that I will be criticized by some for doing it but it has worked fine for our last 2 trailers.
2011 Flagstaff 8528RKWS
2015 Toyota Tundra
wfmdfm is offline   Reply With Quote
