Old 03-06-2014, 09:30 AM   #1
Heating pads
I have and 2014 8282 ws Rockwell ultralite fifth wheel. I am planning on heading south in the next couple weeks. Can anyone tell me whether the fresh water tank is heated with the heat pads. I am fairly sure the black and gray water tanks are. Thanks for your help
Rockwood 8282 WS
2012 F-250 6.2
farfetched is offline   Reply With Quote
Old 03-06-2014, 09:37 AM   #2
LittlePM's Avatar
I don't have an answer for you, however, it's cold in the south too, at least here in Alabama. Stay warm.
Pennie and Chuck, Mandi and Polly (the little dogs)
Your Hosts for BamaGanza 2017
2014 Georgetown XL378, 2013 Honda CR-V AWD Toad
Days Camped 2014 - 83, 2015 - 56, 2016 - 58, 2017 - 86
The Home of the FREE because of the BRAVE
LittlePM is offline   Reply With Quote
Old 03-06-2014, 09:46 AM   #3
dcheatwood's Avatar
I have 8282. I am convinced that all 3 tanks are heated IF you have that option on yours. There is a switch top right of panel that says "Tanks."
Sent from my XT907 using Forest River Forums mobile app
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 03-06-2014, 09:50 AM   #4
dcheatwood's Avatar
Here's a thought. While the weather is really cold, and tank heaters are on, run some fresh water from the tank and see if the water is as cold as the outside temp. Of course this will not work if you are running furnace, as that also heats the underbelly.
Old 03-06-2014, 09:53 AM   #5
Really not into testing right now, outside temps this am were - 10. I thought I read where the pads were on the gray and black only, that is why I was asking thanks
Rockwood 8282 WS
2012 F-250 6.2
Old 03-06-2014, 09:56 AM   #6
BigTJohn's Avatar
If you have "tank heaters" then yes - fresh, gray, black tanks are heated. They come on at 40*f and off at around 60*f. I would shut them off if the temp is above freezing as it is a load on the converter/battery combo you do no need..
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 03-06-2014, 10:29 PM   #7
The FW tank is heated, as are the GW and BW tanks, but NOT the dump/gate valves. Found this out the hard way last fall on our extended 3 month trip up north to visit the granskids. We specified to the dealer what we were planning to do with the V-Lite and special ordered the unit with thermopane windows. Spent nearly every AM in Nov & Dec outside with a heat gun on the gray water valve. I've since installed heat pads on both valves.
Road Home
Chuck & Linda
Olive Branch, MS
2013 Flagstaff V-Lite 30WRLS
2013 F150 EcoBoost/Max Trailering Pkg.
Road Home is offline   Reply With Quote
heating
