07-19-2019, 08:16 PM
Princess Kelea
Help Again Please! - front jack switch
So, my front power jacks have not worked - the flip just flopped and didn't engage anything - today my neighbor was taking a look for me and discovered the switch is broken. We live in a pretty remote area. Any suggestions where I can replace this online and what exactly to search for? I tried searching but I'm not finding the exact item.
I have a few pictures to share. This is what it looks like. The rear works fine. Well, mostly.
2015 Salem Hemisphere Lite 232IS
2007 Ford F-350 4x4 Diesel Super Duty
Jesus Saves!
07-19-2019, 08:41 PM
your middle picture has all the info. it is a sigma 260 series rv spdt switch. it is probably a momentary contact. they are all over the internet. i think there were some on ebay. just make sure you get the proper one. my guess is that the switch may come out of the bezel but i saw several that came with the bezel also. cost $10 - $15 max! rv supply places might have onE also. or perhaps the power jack manufacturer. this is repairable!
what remote area of arizona?
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
07-19-2019, 10:38 PM
Princess Kelea
Paulden, north of Prescott.
I searched for the numbers but couldn't find the exact thing and being a newbie I was afraid to buy the wrong thing. I went to Signa website but it had more numbers that I couldn't find on the 260 Series. I will try again. Thank you.
07-19-2019, 10:39 PM
Princess Kelea
And hello Payson! My dad's in Pinetop.
07-19-2019, 11:30 PM
Looks like Lippert has changed to new look. You can get it on Lippert's website, Amazon or here for $7 cheaper.
https://www.ebay.com/p/LCI-At141-121...AaAlWMEALw_wcB
If you find them for 10 or $15 please post where and I'll pick up a couple for back-ups.
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
07-19-2019, 11:47 PM
Princess Kelea
Originally Posted by bob213
Okay, since I wasn't the one to crawl under the trailer and take this apart - seeing these wires was bothering me since there are no wires on mine. Can I assume the part the wires are coming off of is what my pictures show and these wires attach to those prongs? My understanding was this plus (with the oxidation) just plugged into another plug receptacle/box thing (sorry - I don't do this stuff and don't know the proper names). I was searching for exactly what is shown in my pictures. Thanks for not making fun of me.
Jesus Saves!
07-19-2019, 11:57 PM
07-19-2019, 11:59 PM
Princess Kelea
Yes, the switch came out of the bezel. My confusion comes from the pictures only showing the switch part and not the actual blades such as mine has. I don't know how to select the proper one because I can't visually see the side with the blades/x on it. I'm going to upload another picture. Is it possible two of the blades on my plug were broken off? I'm seeing these switches with 3 connections or 6 connections but I honestly don't know which mine is. Sorry to be a pain - and thanks for the help.
Jesus Saves!
07-20-2019, 12:03 AM
Princess Kelea
Okay, looks like I'll be going under it tomorrow to figure out just what he unplugged. I didn't realize it was several blade connectors like the one he's removing in the video. Appreciate the video and the visual.
Jesus Saves!
07-20-2019, 12:15 AM
Just noticed yours only has two mounting screws. Only find that in white...
https://store.lci1.com/rear-electric...-harness-white
07-20-2019, 12:22 AM
I believe you will only have 4 blades. Positive/negative/extend/retract. You may have to connect +and- and then test to see which is extend/retract.
07-20-2019, 05:14 AM
when i quoted the price i was looking at the base sigma switch. the entire replacement assembly from lippert is more. but that video is pretty good. and i saw four terminals on the switch that you took out and the replacement switch assembly had four wires on it. it is repairable!
we've been to prescott from the south and the east but have never taken the road out to the north which goes through paulden. someday! SO MUCH STILL TO SEE!
07-20-2019, 08:24 AM
I just replaced one of these a couple of weeks ago. My local RV dealer was actually the best price! The new switches seem to have been changed to eliminate the spade connectors and are directly wired. To replace, you may have to add a crimp on spade connector to the wires on your new switch. The one I bought still had spades (I guess it was old stock) but didn't show the cross connected bars that are on yours and my older switch. The newest switches that I found online were all ones with "pigtail" wires instead of spade connectors.
The Lippert part number for the switch I used is Lippert #387874.
07-20-2019, 12:45 PM
Princess Kelea
https://www.etrailer.com/Accessories...=.why-etrailer
This is EXACTLY what was removed. But it says it's for steps? Oi vey, who knew owning a TT could be so much fun!
Will this work?
Jesus Saves!
07-20-2019, 12:59 PM
Looks like an exact match to me. The description says "self centering". That means you have to press the up/down side constantly to run the motor. You should be able to use this switch.
07-20-2019, 01:22 PM
Did you look on the jack MFG web-site?or in your manual? I was able to find the part number this way for mine and then ordered it on Amazon.
07-20-2019, 01:32 PM
https://www.rvupgradestore.com/Multi...-p/19-2010.htm
Check out above link at RVUpgrades MFG P/N: 13635
MFG: JR Products
Less information but also on Amazon $9.41 Prime
2017 Montana HC 353RL added Disc Brakes, Progressive SURGE PROTECTOR.
2017 Ford F350 6.7L Dsl., CC, SWR, LB, B&W Companion #BWRVK3300 OEM Prep mtg.
PAST- 2012 Coachman Leprechaun 319DSF w/TOAD -2011 Chevrolet Equinox 4-cyl. AWD, 2008 Springdale 266RL, 2002 Outback 25FB
07-20-2019, 03:57 PM
Princess Kelea
Originally Posted by Pathfinder75
I did - and they were showing the one in the video that was posted earlier.
I ended up ordering the one I posted the link to that shows exact match except it says it's for step use - the distributor is telling me it won't work but they've got a call request into Lippert (stabilizer mfg). My head is currently spinning and I really just want my jacks to work.
Thank you for this though - it looks like the switch and a cheaper option - question - it says it's a DPDT switch and someone else posted I need a SPDT switch? I have no clue or why. If I go to Sigma 260 Series (as shown in my pix) they have several letters that correspond to spdt and dpdt - for on/on, on/off/on, mom-on/off/mom-on, etc. I know when I press the switch for the rear jacks I have to hold it up to extend them until they are where I want them. I also have to press and hold in the opposite direction to retract them when I want them back to their original position. So, is that a mom-on/off/mom-on configuration?
I'm sorry, I'm not an electrician and all this electrical stuff is over my head, in spite of being a rather intelligent person.
Jesus Saves!
07-20-2019, 04:08 PM
i was incorrect! it needs to be DPDT with the reversing feature. and yes, that you have to hold the switch until you get the jacks where you want them is the momentary feature. i can't see how it would make a difference between steps and jacks. the reversing feature is those two metal strips that make a cross on the terminal sides.
07-20-2019, 04:31 PM
Did you try contacting Sigma and ask for a replacement? If you send them the picture they may have an exact replacement. This is a very similar switch that may replace it. I can't tell the dimensions of the one you have but this may be the same.
https://www.amazon.com/JR-Products-1...t_sims?ie=UTF8
