Old 10-12-2016, 07:58 AM   #1
jbhodj's Avatar
HELP Frost Freeze Warning Iowa
Howdy folks
Iowa weather forecast is predicted to have some cold temps tonight thru Thur with lows below freezing.
Have not not winterized the camper yet or anything. Now I'm a little nervous if I am good for now as I don't or can't get around to winterizing until next week
Will everything be ok for this short cold spell or shud I take precautions to avoid issues
Thank ya
jbhodj is offline   Reply With Quote
Old 10-12-2016, 08:10 AM   #2
For the past month, I've been using an air compressor to blow all the water out of my RV plumbing, draining the water heater and draining all holding tanks between camping trips because unexpected overnight freezes can pop up at anytime. This is a stop gap measure until I can fully winterize with antifreeze.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 10-12-2016, 08:16 AM   #3
Flybob's Avatar
You need the temp to go below freezing for a few hours to do damage. If that is forecasted , you can simply blow out the lines with a small air pump until you get a chance to spend some time on it.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 10-12-2016, 08:26 AM   #4
TURBS's Avatar
It would have to get below freezing for many hours to be concerned
I see a low of 34 tonight and 39 the next day and I'm in eastern Iowa.
I'm not worried till it's going to be 25 for 6 hours or more
TURBS is online now   Reply With Quote
Old 10-12-2016, 09:31 AM   #5
jbhodj's Avatar
We now I can rest easier. Thanks
Old 10-12-2016, 09:41 AM   #6
waiter21's Avatar
If your traveling or living in the MH, and the call is for overnight frost warnings, your probably OK as long as there is heat inside the MH.
Frost is generally caused by the earth radiating its heat skyward. If there is something above the ground to reflect/re-radiate the heat, i.e. clouds, bottom of MH, etc., you don't get frost because the heat radiated by the ground is reflected or re-radiated back to the ground.
A temperature excursion of a couple degrees below freezing for a couple hours should be OK.
If you have a City water connection and hose, you may want to turn it off and remove the hose as a preventative measure.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2001 Civic
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 10-12-2016, 10:10 AM   #7
mjones12's Avatar
Correct. Outside temp at freezing doesn't mean water temp instantly goes to freezing.
2013 Surveyor SP220
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 10-12-2016, 10:32 AM   #8
Just had three nights here in PA where temps got to lows of 27º to 30º.
With NO heat in my 5th wheel the remote temp indicator showed INSIDE RV temps of 35º and 38º degrees on those nights. (my remote thermometer retains hi & lows for the day)
It would take more than just a couple of overnight hours of <32º temps to freeze where damage could occur.
If you still have concerns... plug in a small electric heater and let it run overnight.
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 10-12-2016, 11:00 AM   #9
Cedar Rapids here and the warning is for 7 hours, 2am to 9am Thursday morning. My apps all show only about 33 as the low. I am not concerned at this point. Friday and all next week the temps pick back up.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Nights camped 2016-43
Nights booked 2017-21....so far
Electra glide is offline   Reply With Quote
Old 10-12-2016, 11:04 AM   #10
It only takes a few minutes to blow the water out and then you don't have to worry.
