Old 12-14-2007, 11:04 PM   #21
Opps - this is true for butane, but not likely if you are actually using propane. Butane vaporizes at about 32 degrees F, propane at about -40 degrees F.
Harve is offline   Reply With Quote
Old 12-19-2007, 10:16 AM   #22
LESLIEandVIC's Avatar
Ahh it dont get quite that cold here (san diego)
But ok check this so i got it working then it stops working when i change to a full tank or switch over to a full tank.
It starts working when the tank is not quite full.
Is it a chance that the tanks could be too full for the heater to work?
Stove works and all but i donno its strange.
so its like this...... for the last 4 days it worked untill the tank was empty, i put a full tank in and its not working. What i will try is fill a tank only with 5 gals instead of 7 and see what happens. I will let you guys know.
Im still having trouble finding a mobile service tech =(.
2007 Salem 392PT FLFB
LESLIEandVIC is offline   Reply With Quote
Old 12-19-2007, 11:11 AM   #23
kinda sounds like my gas grill
when I put a new tank on and open the valve fast it doesn't work, pressure is really low
but I open the valve slowly it works
dunno, maybe something else to try?
greg
aintgotnun is offline   Reply With Quote
Old 12-19-2007, 11:47 AM   #24
greg
I will give that a try for sure,
Another thing, the starter is what does not work when its not working. Is there a sensor for the gas going in?
Old 12-19-2007, 12:26 PM   #25
The Jolly Mon
NDJollyMon's Avatar
Send a message via Yahoo to NDJollyMon
Is it possible that when you run the tank empty, it won't relight because the line has no propane? After a few attempts, does it relight after the new tank is installed?
I've always been told to open the cylinder valve VERY SLOWLY as well.
There should be a flame sensor that detects whether there is flame or not. It stops the flow of propane if it does not light right away.
Check out this furnace link:
http://www.rverscorner.com/furnace1.html
Pete (Jolly Mon)
2018 Wildwood Grand Lodge 42 DLTS
-Seasonal Space, Northern MN.
-2017 Sylvan 8522 LZ LES/115 Merc/Sea Legs
NDJollyMon is offline   Reply With Quote
Old 12-19-2007, 12:38 PM   #26
Il try that slow valve open and see if it changes anything.
I tried for about 2 hours last night taking the thing apart, trying and trying again. It does not work.
Im going to do a test today tho for sure. fill second tank 5 gal instead of the 7 and see if any changes and that will give me the answer to the thought. haha
Old 12-21-2007, 10:40 PM   #27
welshman599's Avatar
Send a message via MSN to welshman599
Not an expert at all, but two things just in case.... are you opening your propane tank valves fully? They need to be. And how about your hot water heater... are you getting a good full flame from it when the furnace isn't working? The stove doesn't take much pressure to light and run quite well, while the furnace and water heater need a good full pressure to operate and won't fire well without proper pressure.
Just a couple of thoughts Vic... I hope you get it resolved soon.
  • Salem 401-2b; 31" Sony Trinitron and two channels on the antenna.
  • Smokin' hot wife... 2 boys, 25 and 10.
83 sweet sweet days camped in 2008 - not easy in my neck of the woods!
welshman599 is offline   Reply With Quote
Old 12-22-2007, 09:51 PM   #28
Vic, I am sorry to here that you are still having problems with your Heat, I didn't think It was going to go away on it's Owen. It doesnt matter whether the fuel thanks are at 7lbs or 5lbs, the heat should still work. Yes you should ALL WAYS open your tanks slowly and completely. Open the tanks slowly because you may damage your gas regulator just out side of the tanks. Now If I understand correctly, you said that the electronic starter will not make a clicking sound on a second try? then there is possibility that the transformer that generates the power for the electronic starter may be starting to show signs that it is getting weak or It may have been bad from the start. As far as the proper fuel pressure for the furnace there is a component called an orifice that is connected to the end of the fuel line inside of the furnace, this orifice has a set value to allow a certain amount of fuel in at a steady rate, and will not change unless it becomes clogged up with dirt then it will restrict fuel flow. I hope you find the problem soon. I am sorry you are so far away because I would be happy to come help you trouble shoot and get it straight.
Old 12-26-2007, 09:29 PM   #29
Any update on the problem Vic?
Old 12-29-2007, 02:03 PM   #30
Love My Sunseeker
DXSMac's Avatar
Actually, I had that same problem in my sunseeker. Turns out it was the thermostat. Cost me $150 to replace the thermostat (I had a dealer do it).
Check the thermostat.
JJ
DXSMac is offline   Reply With Quote
