Help me identify my slide. 08 Flagstaff 831BHSS
This is my new to me TT. Before I bough it I gave it a pretty thorough inspection. I did notice a spot at the bottom left of the rear slide (bunkroom). It was just an indention about fist size. At first I thought water damage and was concerned, but after I looked at it closely I didn't see any signs of moisture and it was very solid. Everything checked out good, so we took it home.
At home I had the slides out for a couple days, and we have been getting a ton of rain lately. I noticed the rear slide wasn't quite centered in the opening, and there are some gaps in the seal. Being new to having a large TT with slides I didn't think too much of it at the time. Well, now I see some water has definitely found it's way into the bottom corners.
So, I think to fix it, I need to adjust the height and side to side position. I've tried looking around, and my slide looks different from everything I'm seeing out there. It doesn't have the typical adjustments from the outside like everyone else I've seen.
Can you all help me identify what type of system I have and how to adjust it, or at least where I can find some documentation on it.
I see a couple places the could be adjustment points. I labeled them in the photo. #1 looks like I can adjust it left/right, and looks like there is a white line from the factory which my slide has moved away from. Looks like #2 could be the in/out adjustment. Where is the up/down adjustment. You can see in the last photo, that my decals don't line up and you can see some dirt behind the top of the slide showing. This indicates to me that it needs to be adjusted up some.
