07-25-2017, 08:08 AM
HELP me replace my porch light! Microlite 23 LB
We have had our 2017 Flagstaff Microlite 23LB for less than a year and our porch light is already burnt out. We can't figure out how to get the cover off to replace the lightbulb. It doesn't "pop" off or have any visible screws. Anyone have any idea's? THANKS!!!
07-25-2017, 09:57 AM
try squeezing the top and bottom of the lens at the same time. Mine popped out when I did that. Good luck with yours!
07-25-2017, 10:10 AM
Just noticed my porch light was out on our last trip. Just put a little screwdriver in slot at the top of the lens and gently popped it off. Was easy. The light is #1141. may not apply to your trailer though.
Dwayne and Susan
Jiro and Phoebe-4 legged family members
Mike and Dana - Traveling buddies
2016 Ford F350 XLT 6.7 Powerstroke DRW 4X4
2016 Brookstone 395RL
07-25-2017, 10:11 AM
Yep, some squeeze top and bottom, others squeeze side to side. Most have a small slot somewhere that you use a screwdriver in to pop them off.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
07-25-2017, 01:36 PM
That's how to do it but Don't replace with an incandescent bulb. Time to go full LED. I would get the bulb out and go online. Look at the many options for LED the buy 10 or 20 to go throughout the rig. eBay cheapest Amazon has some good deals. I found some I am ok with, replaced the couple that were not LED from the factory and I have a big bag of them at an average cost of about a buck a bulb. I share them with other campers considering how to save battery. Makes me a hero every time and 20 cost about the same as two.
Tom48
In Sunny So Cal /w
Now in 2005 Holiday Rambler Ambassador DP and The Hot Air Balloon RESTLESS
NO MORE Tricked out
2017 Sandstorm 250 T.H.
07-25-2017, 01:56 PM
thought about LED but we hardly use it and I had an 1141 available. We do have the LED light strip just under the awning so we use that mostly.
Dwayne and Susan
07-25-2017, 01:57 PM
Are you sure it is the bulb?
The switch on mine had become corroded so I replace the fixture with an LED model from Amazon.
2023 Coachman Apex UL 243FKS, 2016 F150
07-25-2017, 03:53 PM
If you only camp with plugins and don't boondock, then use your spares, but maybe think of getting some LED's after that.
We had to use a small flathead screw driver to get our lense off. good luck
2015 FR Classic 625D
2011 Toyota Sienna XLE
07-25-2017, 05:44 PM
ARLO
Don't waste your money on LED lights. For all the balls you use with the old campgrounds buying the electric who cares you can buy regular bulbs for pennies and LEDs for a dollars stick with the regular bulbs.
07-25-2017, 06:01 PM
Wow
How about the PITA to always change the bulb? My incandescents lasted two weeks each of 3 changes, My 2 LED's cost $12 and last 50K hours.
Waste a dollar to save a dime.
2015 F-250 FX4
07-25-2017, 07:59 PM
I changed to LED. Not because of a burnt out bulb, but because of the heat put out by the standard bulb. After being on for a couple of hours I swear it was hot enough to melt the plastic. Jay
07-26-2017, 06:31 AM
16 LED bulbs consume the same as one regular bulb in an hour. get eth super white ones and change them out. on the lens to remove there are 2 tabs on one side and 1 on the other (top and Bottom) you can use a small eye glass flat blade screw driver to flip the lens cover off. I changed my bulbs on the 2018 Sportster toy hauler we just purchased.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
07-26-2017, 06:57 AM
"On the road again"
Originally Posted by crunchman12001
Wow
X2
When we took delivery of our Cardinal two months ago and got it home, I realized BOTH of the "scare lights" were burned out. I ordered LED bulbs and replaced both. I didn't get LEDs for electricity savings, but for longevity.
Robert & Estha Shiflet
Georgetown XL 378TS
Jeep Gladiator Willys Tow Vehicle
07-26-2017, 07:11 AM
Throw out the lamp...before checking the bulb ?
07-26-2017, 07:55 AM
they are also white not yellow for light casting. another reason to switch
07-27-2017, 06:21 PM
Watch you dont put the wrong size bulb in I did and I melted the shade I have to replace the shade.I have a 21 FBRS micro lite
2019 Flagstaff 26 RBWS
2015 GMC Sierra 1500
2019 camp 17 nites. Bill,Alley and are two kids Sierra,Ivy. 2020 camp 9 nites
07-27-2017, 06:59 PM
Another reason to switch to LED's. No heat to melt the lens.
2015 F-250 FX4
