Old 07-05-2019, 07:01 AM   #1
Help !!! Someone stoled my floor
Long story short, I noticed a leak outside whilest we were camping last week. I was sitting outside and there was water dripping out from where the front corner of the shower is.
I already knew what was happening, water was coming from that spot and leaking.
Fast forward to today where I unscrewed the access panel (way to small) under the tub. I was amazed to see that someone had stolen a section of my floor where the P trap is. So there is nothing between mother nature and us but the tarp covering underneath.
I figure that they did this to give the trap some room. As it is a plastic tub and flexible.
I am going to cut the covering and screw in 2x2 around the edge of the opening from the bottom. Then using a piece of plywood, screw it into the 2x2's thus giving the P trap it's room and closing off the entrance to any thing seeking cold/warmth from the elements. Click image for larger version
tyler811 is online now   Reply With Quote
Old 07-05-2019, 10:16 AM   #2
Head Rambler
That's typical. The covering is pretty animal proof, but closing it off is a good idea and adding some insulation wouldn't hurt anything either.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 07-05-2019, 10:33 AM   #3
Typical factory workmanship...
We had something similar next to the furnace. A flexible duct ran down into the underbelly and came back up in the kitchen area. They just whacked a big square-ish hole in the subfloor plywood for the duct and called it a day. I screwed and glued some 1x2 around the perimeter and then screwed some 5/8" ply onto that with a hole in it for the duct.
I found a few other "oversize" holes in the floor for plumbing and used some spray foam to seal them all up.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 07-05-2019, 10:41 AM   #4
Iwannacamp's Avatar
Im not sure if it was a plan. The bedroom in our unit has NO HEAT. No duct and not a simple way to get heat in there as storage and floor level affect it. I need to remove the chloroplast and see if I can add there.
2017 Puma 297RLSS
floor, led
