Old 04-07-2018, 10:27 AM   #1
Help with installation Furrion Rear View camera
We have a 2017 5th wheel Chaparrlal 336TSIK. I am trying to add a Furrion rear camera. This trailer has a housing mounted at the top of rear back wall. When I removed the cover on the housing there is no electrical plug - in for the camera. There are 2 wires looped in the housing, a green and a white wire. I assume they go to the running lights. The harness wire that came with the camera has a red & black wire on it.
How do I connect the wiring?
Thanks for your help.
Ourtime0529 is offline   Reply With Quote
Old 04-07-2018, 10:30 AM   #2
I'm trying to remember my install. I do remember I bought the wrong model camera and it came with the housing (so it had extra parts) you may need to take of that housing and look behind? I thought mine had a coax cable but cant remember.
Kimber45 is offline   Reply With Quote
Old 04-07-2018, 10:32 AM   #3
Green is supposed to be ground and white is supposed to be neutral - according to the national electricians code.
Do you have a DC voltmeter?
myxkp is offline   Reply With Quote
Old 04-07-2018, 10:34 AM   #4
I do have a DC volt meter
Old 04-07-2018, 11:01 AM   #5
With your running lights on one of the two wires either the green one or the white one should read 12 volts to ground
Old 04-07-2018, 11:48 AM   #6
I can't check it now. After I find out which is the 12 Volt ( hot wire ), do I assume the other is the ground ? Then do I hook up one wire from the camera harness to the 12 volt ( hot wire ) and the other to the other wire ?
Thanks for all your help
Old 04-07-2018, 11:55 AM   #7
Yes, the one that reads 12 volts is you hot, goes to red for power to camera.
Old 04-07-2018, 11:58 AM   #8
then the black wire on the harness from the camera would go to the other wire on the trailer ?
Old 04-07-2018, 12:03 PM   #9
Mine was white-ground and white with a stripe-hot. The camera is red-hot, black-ground.
Nascon is offline   Reply With Quote
Old 04-07-2018, 12:34 PM   #10
Don't forget that you will probably have to turn on the tow vehicle headlights to see power at the camera wires
Okmechanic is offline   Reply With Quote
