Old 07-30-2016, 07:31 PM   #1
HERITAGE GLEN 368RLBHK awning adjustment question
Is there any type of adjustment for the awning on a 2016 Heritage Glen 368RLBK. It is an electric awning. I would like it to angle down a little. It just goes straight out, the rain puddles up on it and runs off the middle of the sides. A little drop would help alot.
Thanks,
Ray
rsizemore is offline   Reply With Quote
Old 07-30-2016, 08:06 PM   #2
If your awning is like mine, just grab the lower awning arm and pull down. This will lower your awning. I think mine has a sticker on the arm that states pull here. Mine is in storage now or else I would check it for you.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 07-31-2016, 07:49 AM   #3
Thanks Bob, I will try it. Mine is also in storage and will try it next time out.
Ray
Old 07-31-2016, 08:22 AM   #4
Thanks,
Ray
Awning MFG and model# would Help as well as a Pic is even better! Youroo!!
youroo is online now   Reply With Quote
Old 08-01-2016, 06:52 PM   #5
I have the exact same trailer . I was up at storage today so i took a picture in normal and rain setting mode
ID:	116036   Click image for larger version
Jeff from Burlington Ont is offline   Reply With Quote
Old 08-01-2016, 09:30 PM   #6
I have the same or similar awning, but when I pull down on the lower arms, the gas shocks push the awning right back up. I tried tightening the bolts at the joints at the bottoms to see if they would provide some resistance, but they were already as tight as possible. Any ideas?
Sent from my SM-T320 using Tapatalk
2016 Salem Cruise Lite 261bhxl
Ram 1500 5.7l Hemi Crew Cab 4wd
gspot01 is offline   Reply With Quote
Old 08-06-2016, 04:41 PM   #7
Thanks Bob and Jeff,
You are exactly right. All I had to do is pull at the elbows and it will adjust some. The wind and the shocks does push it back up some but it is adjustable and it is labeled. I would be dangerous if I would read. Ha Ha. Attached is a picture I taken.
Thanks again,
Ray
Old 08-06-2016, 08:26 PM   #8
Yes, everybody is correct on pulling the arm down, but you have to tighten down the arms with the black knob, otherwise it's just going to go back up. Make sure the knob is loose before you adjust the arm. Very simple, but you have to really tighten down that knob.
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
tdst51 is offline   Reply With Quote
awning
