Old 03-23-2014, 12:15 PM   #1
Hitch lock for VLite 30WFKSS
Hey all.
Can anyone tell me what they are using as a hitch lock on their 2013/2014 VLite? It seems to have an odd design that I can't find a lock for.
Thanks.
Matt M.
2014 VLite WFKSS
2013 F150 Super Crew Eco Boost FX2
troutermatt is offline   Reply With Quote
Old 03-23-2014, 02:45 PM   #2
Do a google search on DT25013. Only one I could find to fit my under mount coupler.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 03-23-2014, 03:11 PM   #3
When I pulled a tt, I cut the shank off an old 2-5/16" ball and just locked the latch with a regular Master Lock. (you have to grind/file the latch so you can use a regular padlock.) Much cheaper and easier to store the modified ball.
Old 03-23-2014, 04:01 PM   #4
mark0224's Avatar
Never bothered before but am looking into one.
OldCoot when you look under the hitch isn't there a big nut that can be taken apart then the ball you have in there would fall out anyway.
Was thinking on a piece of 1/4 inch Plate and a ball bolted on then welded to plate. 1/4 inch plate to cover the nut on the inside of the hitch then just the regular hitch lock. Would like input on my idea I have most of the parts in the garage already just need a ball ,maybe a cable lock to wrap over the hitch.
mark0224 is offline   Reply With Quote
Old 03-23-2014, 04:48 PM   #5
Just cut the shank off, weld it to the plate covering the nut and put a regular padlock in the latch hole after you open it up. I never did put a plate on it as most that are going to mess with it don't come with a socket to get to the nut and it's usually rusted. lol.
Old 03-23-2014, 06:23 PM   #6
mark0224's Avatar
only reason I knew was padlock buggered up once and had to take it all apart to be able to get at the lock with die grinder, to tight a spot. I think just making sure there is a padlock on the hitch itself is good in most circumstances unless your going to be storing your trailer somewhere other than your driveway.
Old 03-23-2014, 06:31 PM   #7
Only problem with that is someone can back up with 1-7/8" or 2" ball and just drive off with it. The cut off shank 2-5/16" ball prevents that.
Old 03-23-2014, 07:50 PM   #8
Timex's Avatar
I too had trouble finding a padlock for my VLite. I finally settled on this lock. Then I got to thinking about what OC and others said about someone sticking a smaller ball in the hitch, tying it down and driving off. So I used an old ball and the plastic cover off a new ball I bought. Stick it in the receiver, flip the latch down and lock it. Locks are for honest people but this might make a thief think twice. At least make him work for it. Hope these pics come thu.
ID:	48280   Click image for larger version
ID:	48281   Click image for larger version
ID:	48282   Click image for larger version
Timex is offline   Reply With Quote
Old 03-24-2014, 05:33 PM   #9
mark0224's Avatar
Never thought of them using a smaller ball to tow it away thought that would be unsafe will have to look into something then, thanks.
hitch
