Old 01-21-2015, 06:51 AM   #1
Hitch Maintenance
I have a 4 point Equalizer hitch. I have noticed some rust spots. I concerned that if I use a lubricant then I will lose the effectiveness of the sway control.
I appreciate everyone's advice.
Name:	ImageUploadedByForest River Forums1421844665.421708.jpg
ID:	68696Click image for larger version
Name:	ImageUploadedByForest River Forums1421844681.837847.jpg
ID:	68697Click image for larger version
Name:	ImageUploadedByForest River Forums1421844697.920711.jpg
ID:	68698Click image for larger version
Name:	ImageUploadedByForest River Forums1421844708.321158.jpg
Randy
Randy from Texas
TV - 2014 Chevy Silverado
TT - 2014 Palomino Puma 28DSBS
Randy in Texas
TV - 2013 Ford F-250 PS Diesel
Grif76040 is offline   Reply With Quote
Old 01-21-2015, 07:37 AM   #2
geotex1's Avatar
Hi Randy,
You are supposed to clean and lubricate the surfaces where the spring bar pockets swivel in the head as discussed in the owner's manual. I like to use Boeshield T9, which dries waxy and provides a moisture barrier when the hitch is idle. I also otherwise hit the head and bars with a good degreasing, spot prime, and fresh coat of paint every so many years. The paint rubs off in the needed bearing are first trip after painting. Running the same Equal-i-zer for 15 years!
geotex1 is offline   Reply With Quote
Old 01-22-2015, 02:44 PM   #3
You may want to try this product. Was made for mowers but seems to work great on hitches also. Over time the graphite penetrates the metal to give it a black sheen.
Click here: MowerGUARD™ - Graphite Undercoating for Mower Decks and Blades
Happy trails,
billb800si is offline   Reply With Quote
Old 01-22-2015, 03:57 PM   #4
Dodge Guy's Avatar
Well the ball needs to be lubed. The other points as well since they don't offer the sway control. The sway control comes into play at the L brackets on the trailer frame. On my Dual Cam I lube everything except the cams.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 01-22-2015, 04:21 PM   #5
Also Equalizer recommends that you do some annual rust maintenance by knocking off the rust and then using spray paint on the bars/hitch.
drhuggybear is offline   Reply With Quote
hitch, maintenance
